Old 02-11-2019, 09:22 AM   #1
refrigerator
has anyone switched out the gas/electric fridge for a residential fridge? I am buying a 2013 Palomino Solaire 297 RLDS that the fridge works sometimes and thought about switching over to a residential fridge and adding an inverter. Any thoughts would be apprciated .
captrcurtis is offline   Reply With Quote
Old 02-11-2019, 09:31 AM   #2
Flybob's Avatar
You need to consider where you will be staying. If you do not have shore power, you will need to augment your battery bank and charging system. Before you make the switch, do some math so there are no unpleasant surprises.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-11-2019, 09:40 AM   #3
Fulltime family RVer
Buddy of mine did it and he couldn't be happier:
Going residential with the refrigerator – Simpsonsix
I'm really thinking about ditching my Nevercold and going residential.
Old 02-11-2019, 09:50 AM   #4
Thank you for the input, I have done the math have used inverters on boats for many years most likely won't be doing much boondocking wife likes her amenities . If I go ahead with this plan I will put 2 210 AH 6 volt batteries to ensure probably 36-48 hours of continuous run time.
Old 02-11-2019, 09:50 AM   #5
refridgerator
I switched mine out for a Danby I ordered from Walmart. Fit great left to right and was just a little shorter. Added two drawer pulls that matched the rest and run a strap for the doors. I’d do it again in a heartbeat.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 02-11-2019, 09:56 AM   #6
Great, did you add an inverter to run it while traveling?
Old 02-11-2019, 10:09 AM   #7
I haven’t yet, but it pulls less than two amps at 120 so you wouldn’t need much. We keep a couple big blue packs in the freezer part and we put them in the fridge before we leave, it’s good for at least 5 hours travel time and keeps temp. With ice cream! I put foam board in the roof vent.
Also since the doors are reversible you could fashion a bracket on the opposite side from your hinges between the doors with a pin to keep them closed. Just need a flare cap for the gas line and the outlet is already there.
Old 02-11-2019, 10:25 AM   #8
Paul, do be aware that 2 amps @120 volt is 20 amp @12 volt if you elect to install an inverter.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 02-11-2019, 10:53 AM   #9
If the compressor were to run continuously which it does not. I would be curious to know real-life situation how long before his batteries get down to 50%.
Old 02-11-2019, 06:27 PM   #10
it depends on the battery amp hour rating. if you take my example of what i would use 2 6 volt 210 AH batteries you could safely expect 36 hours run time . thanks for the feedback
fridge
