Old 01-20-2014, 02:29 PM   #1
Send a message via AIM to Albert K
Refrigerator
I just got a rockwood mini lite. Kind of curious how long the fridg would work when only on LP? A secondary question, would it be recommended to go to two batteries? Thanks Al
Albert K is offline   Reply With Quote
Old 01-20-2014, 02:52 PM   #2
Old Enough to Know Better
gasman6674's Avatar
Just the fridge uses 1500 BTU per hour, gallon of LP is 91,500 divide by 1500 = 61 hours per gallon. A 20# cylinder holds 4.2 gallons full, 61 x 4.2 = 256 hours per tank. You biggest issue will be 12 volts. Of course any other gas appliances will reduce your run time
Hope this helps
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 01-20-2014, 03:15 PM   #3
KMP44's Avatar
If you plan to do any amount of camping without electric hookups, a second battery is a great upgrade. The high end is a pair (or even 2 pairs) of 6V golf cart batteries. Trojan is probably the most mentioned brand.
However, if you just bought a new trailer, you should have a new 12V battery. What we did, and were very pleased with, was just bought a second, matching 12V battery from the dealer. The key with 2 batteries is they need to be the same type, size & condition. With this setup, you only have to buy one battery (about $100) vs buying 2 6V's that can be $300 or more for a pair.
As the earlier post mentioned, the propane will last days or probably weeks, depending on hot it the ambient temp is, but a single battery may only go 2 days depending on what else is drawing from it.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 01-20-2014, 03:50 PM   #4
Hope this helps
You also have to keep in mind that the gas usage is only when the burner is working which is maybe 5 or 10 minutes an hour depending on how often the door is opened. With 2 fans inside the frig and 2 outside on the coils, ours only fires the burner about 10 minutes every 2 -2.5 hrs.
Old 01-29-2014, 08:01 PM   #5
Note the 256 hour calculation for propane use in the frig assumes the frig runs 24 hours a day. I reasonable weather it would probably be closer to 50% usage. The circuit board draws about 1.3 amps. If you know your battery capacity you could figure out battery life. A good 24 series deep cycle battery will run about 17 hours with a 5 amp draw so you are looking at somewhere around 75 hours. At that point you have reached 50% battery capacity and it should be charged but it will provide power for a longer period.
cadman99 is offline   Reply With Quote
refrigerator
