Old 03-25-2014, 05:43 PM   #1
Refrigerator
This is the BEST site to help someone out who is just starting. I bought a 2007 rv and the refrigerator didn't turn on. The lights for the fridge seem to get no power at all. When I select either gas or electric...still nothing. The whole thing just seems dead. Could it be the board or wire? Anyone have any suggestions....Thanks again...T
Tony Smith is offline   Reply With Quote
Old 03-25-2014, 05:51 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Have you checked all your fuses and reset any circuit breakers? Are you plugged into a known good ac power source? Is there anything else that does not work including all your AC outlets, lights, etc. Once you can isolate that the only thing that does not work is truly the fridge, then you can start thinking about something internal to the fridge itself. If so, the first thing I would do is pull the panel off the back side of the fridge and while using a volt meter, check that the power inlet has power. Do you have the schematic of the fridge to work with?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 03-25-2014, 05:51 PM   #3
rbq
Open the outside fridge cover. Look on the stack, probably on the right side. There will be several wires hooked to the stack. In between the wires there is a small resetable circuit breaker that you just need to push. This trips if the fridge overheats or is out of level for an excess time to protect the fridge from overheating. Had this happen to mine & was relieved to find that the fix was that easy. Check this out first.
2014 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 03-25-2014, 05:56 PM   #4
Lloydg's Avatar
This is good to know. Good suggestion.
Old 03-25-2014, 05:59 PM   #5
rbq
Go to this link and look on the 2nd page. There is a picture showing the stack & the circuit breaker
Dometic - UGH !!!! -warranty/troubleshooting issues.
Old 03-25-2014, 06:02 PM   #6
Ford Idaho's Avatar
While you have the cover open look for Mud Dauber nests.
Old 03-25-2014, 06:05 PM   #7
Oaklevel's Avatar
Just askin' since you are new, the refrigerator does not make much if any noise its not like a compressor type also it will take several hours to cool down.
By the way welcome to the Forum
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-25-2014, 06:22 PM   #8
The refrig seems dead...no lights at all...no cooling...it's like it is getting absolutely no power to unit
Old 03-25-2014, 06:27 PM   #9
TURBS's Avatar
Theres fuses behind this cover if its a dometic.
You'll access it from outside.
TURBS
Sabre owners united!
Old 03-26-2014, 12:31 PM   #10
The frig light may be a clue or the bulb or switch might be bad.
If you take the outside cover off and the frig is operating on gas you should be able to see a small flame - about like a pilot light on the right side - you have to peek around the cover to see it. (make sure you have propane). If there is a flame the frig should be working - allow 24 hours for complete cool down.
The light in the frig and the circuit board use 12vdc for power. You need to check fuses and make sure the frig is getting 12 volt power (note it helps to have a good battery).
In the electric mode it runs of 110VAC - so you need to be plugged in for that.
It could be the circuit board but if you are getting the flame it should be okay. The last possibility is the frig is "broke". This can happen if it has been run when off level - more than 3į. There is no simple fix for this.
cadman99 is offline   Reply With Quote
refrigerator
