Old 06-20-2015, 02:55 PM   #1
Refrigerator
Should water come out of the refrigerator drain tube at a fairly steady rate. Was out in my trailer for 10 days and no water came out of the drain tube at all. Just seemed strange as I had bug screens put on the refrigerator vents and the drip tube goes thru one of the screens now. Just want to make sure water is not going inside trailer somewhere I can't see. Thanks
twosocks is offline   Reply With Quote
Old 06-20-2015, 03:18 PM   #2
mud yapster's Avatar
The drain tube should be installed thru the vent cover at the upper part of the cover so as to form a pee trap so warm air can't make it's way back into the fridge compartment. If you had been using your fridge for 2 weeks and just turned it off the extra condensation water is probably just from ice thawing out off the fins and draining out.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
refrigerator
