Old 04-07-2012, 07:30 PM   #11
Both side to side and front to back are equally important to make the unit function correctly. It should be as close to vertical and horizontal as possible. I understood it was ok side to side and the OP was concerned with the vertical front to back.
Old 04-12-2012, 04:25 PM   #12
rracer5's Avatar
Originally Posted by dunnnc View Post
I would make sure the refrigerator flange around the outside face was flush against the cabinet and then I would look into shimming the top & sides out to level it. Appears the cabinet it is mounted in may not be perfectly vertical to the floor or the mounting flange on the refrigerator itself is not square with the box itself.
X2 on the "wall" it's mounted in. I bet that if you put a level verticaly on the wall or cabinet next to the fridge, you will find it "out of plumb" ceiling to floor.
That being said, other than the door not staying open while trying to get the beer out, that small amount of "tilt" will have no ill affect on the fridge's operation. It would have to "tilt" more than 3-5 degrees side to side affect it's operation (learned this myself the hard way).
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
