Old 08-01-2019, 10:35 PM   #1
Refrigerator door opens when towing
My factory installed refrigerator door keeps opening while Iím towing. Is this normal? It also needs extra attention when you close the door during normal use as it is hard to latch. Is this a mis- aligned fridge during installation?
Kevinhi is offline   Reply With Quote
Old 08-02-2019, 02:07 AM   #2
CincyGus's Avatar
Sounds like it maybe/might be.
Normally there are locks, latches of some sort to prevent it opening while traveling. As far as needing extra care when closing, is your camper level or very close to level when this is happening? I apologize if this sounds like an internet tech telling you to unplug your router and plug it back in when you call with an issue ;-) but you'd be surprised. If the answers yes and your still under warranty, I'd take a look at how the door mounts, check to see if the seal around the door looks fairly evenly spaced or if it looks misaligned as a second part of the door mount needing adjustment.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
door, refrigerator, towing
