Old 03-14-2016, 10:19 AM   #31
TURBS's Avatar
Refrigerator - Gas or Electric Cools Better?
Originally Posted by Kenny kustom View Post
Where did you tag the 12v inside the fridge?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Outside fans.
Lower left hand of outside fridge compartment.
There's a black cover on a box, inside you'll find a 12v circuit that is live when fridge is on and dead when fridge is off.
For the inside fridge fans use the power for the light.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-14-2016, 10:41 PM   #32
Ok, so do these fans work all thw time, or only when light is on. Im confused ?
Kuba is offline   Reply With Quote
Old 03-14-2016, 10:56 PM   #33
Bluepill's Avatar
All the time. Power is taken from the supply side of the switch, not the load side.
2008 Itasca Meridian 37H
Old 03-15-2016, 05:23 AM   #34
World Wide Wanderer
wahoonc's Avatar
I put my outside fans on thermostats, inside fan I use an alligator clip on the negative side for quick disconnect. If it is cool outside and the fridge is holding a decent temp I will disconnect the inside fan. I monitor my fridge and freezer temps with the Accu-Rite wireless system. I liked them so well I bought a couple for the house fridges too.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-15-2016, 06:52 AM   #35
TURBS's Avatar
The interior fans are on as long as the fridge is on, there is also an on/off switch on fan bracket to manually turn fans off.
The exterior fans are on a thermostat but are also only on as long as fridge is turned on.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-15-2016, 06:54 AM   #36
SeaDog's Avatar
Fans are easy to install I used two snap discs to control 12v to fans, one on boiler of fridge a 150* snap disc controls power supply to fans and one at fans 90*up in the chimney. This way the fans only run if the fridge is turned and hot and not when fridge is off and the sun is beating on the side wall heating the compartment to above 90*
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 03-15-2016, 06:59 PM   #37
Nice! Tnx guys. Next mod on the list
Old 03-19-2016, 03:23 PM   #38
Cajun Style's Avatar
http://www.amazon.com/Valterra-A10-2...s=valterra+fan
Works great for me, has a T- stat comes on at a certain temp.
Harry-O
Cajun Style is offline   Reply With Quote
Old 03-19-2016, 03:39 PM   #39
http://www.ebay.com/itm/Dometic-Refr...hS5BW9&vxp=mtr
Here is another good one!
Harry-O
Old 03-19-2016, 03:40 PM   #40
http://www.snip-the-tip.com/
And another!
Harry-O
electric, gas, refrigerator
