Old 03-13-2016, 08:21 AM   #1
Refrigerator - Gas or Electric Cools Better?
Has anyone done testing or has seen a reliable test report concerning whether the Dometic RV refrigerator cools better when on LP gas or on 120 volt electric power? Most of the time mine cools very well on either heat source, but a few times when it was over 95 degrees with the refrigerator side in the sun it got above 50 in the main compartment. In such a case I'd switch to whichever cools better. I plan to add fans both in the interior coils and on the exterior coils to help, but using the best heat source would help, too.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 03-13-2016, 08:31 AM   #2
TURBS's Avatar
Gas and fans!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-13-2016, 08:44 AM   #3
SeaDog's Avatar
I have not tested my new Flagstaff with domestic fridge, however my winnie with a amish cooling unit and two fans in the chimney got colder on propane.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-13-2016, 11:17 AM   #4
World Wide Wanderer
wahoonc's Avatar
IIRC the LP puts out more BTU's than the electric, meaning it will cool better. The key is to get the hot air out of the compartment and keep air moving across the coils.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-13-2016, 11:41 AM   #5
Aaron
Where did you get the information that the gas burner has more BTU'S than the electric heater? I haven't seen it.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 03-13-2016, 11:45 AM   #6
Propane does a better job than electric.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 03-13-2016, 12:36 PM   #7
World Wide Wanderer
wahoonc's Avatar
Read it on the internet so it has to be true!
I have seen it in the fridge specs, I will see if I can find the exact numbers, it varies a bit from brand to brand and by the size of the fridge. It is not a massive difference, but the gas does put more heat into the system than the electric if everything is equal.
As I stated before, getting air moving is the number one thing, keeping the incoming air as cool as possible is the second, park the fridge side of the RV in the shade on a hot day, if at all possible. Circulating air around in the fridge section doesn't hurt either.
Aaron
Aaron & Rhonda
Old 03-13-2016, 01:00 PM   #8
Read somewhere (probably this forum) that adding a sunshade on the outside wall where the fridge is will improve cooling. Just need to make sure there is a space between wall and shade so air can circulate.
rogerkathy is offline   Reply With Quote
Old 03-13-2016, 01:28 PM   #9
Originally Posted by TURBS View Post
Gas and fans!
2015 Columbus 320RS
2008 2500HD Duramax
Fans??? Diy?
Kuba is offline   Reply With Quote
Old 03-13-2016, 01:57 PM   #10
World Wide Wanderer
wahoonc's Avatar
Originally Posted by Kuba View Post
Fans??? Diy?
Yes. I typically use the Valterra one on the outside in the fridge compartment and a computer hard drive cooling fan attached to the fins inside.
Stay away from the Camco Solar Refrigerator vent, they don't last long and when they break the allow water into the fridge area.
Aaron
Aaron & Rhonda
Old 03-13-2016, 02:30 PM   #11
CDR USN Ret
I Googled a tech spec sheet showing a Dometic RM1282 inputs 2080 BTUH of propane. Assuming it's about 70% efficient at converting the energy input into cooling capacity, that would give about 1400 Btuh of cooling on gas.
Same sheet shows electric heater is a 210W heater. This converts to (210W x 3.4 Btuh/W) 714 Btuh. The electric heating element is probably close to 90% efficient, so about 643 Btuh of energy goes towards refrigeration.
So the gas provides about 2.5x as much cooling effort.
However, both the gas burner and the electric cycle on/off as controlled by the thermostat.
If the heat entering the food section (for this refrigerator) was less than about 643 Btuh, both can keep up, but the electric heating would be on for 2.5x as long as the gas burner would.
If the heat entering the food section was more that 643 Btuh, the electric element could not maintain temperature. The gas could maintain temperature as long as the heat entering the food section was less than about 1400 Btuh. Above the 1400 floor neither source can maintain box temperature.
All the other reefer specs I saw had about the same ratio between the gas input and heater watts.
Here's my take-away. If I start with a warm frig (or load it up with warm product), and I want it rapidly brought to set temperature - I should run the frig on gas. Once I have the box and food cooled, the electric should be able to hold it.
I'm going to take a look at my (RM135) manual and see if the "AUTO" control will monitor box temp and if it sees the electric is not holding temp, will it cut on the gas.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 03-13-2016, 02:36 PM   #12
bikendan's Avatar
DITTO!
Equalizer WDH
Old 03-13-2016, 02:46 PM   #13
Stank Bait's Avatar
Gas gets it colder. Have had -7˚ on gas.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 03-13-2016, 02:47 PM   #14
TURBS's Avatar
Fans??? Diy?
This on the inside
And a couple of 120mm computer fans on the exterior.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-13-2016, 02:58 PM   #15
northstar1960's Avatar
This on the inside
2015 Columbus 320RS
2008 2500HD Duramax
I can see adding fans to the outside coils and even a circulating fan on the inside , what i see in your pic looks to be over kill in a big way . since those fins just pull the cold from the cooling plate i would think to much air on them would hurt the efficiency of the fins . IMO .
northstar1960 is offline   Reply With Quote
Old 03-13-2016, 03:04 PM   #16
Stank Bait's Avatar
"since those fins just pull the cold from the cooling plate i would think to much air on them would hurt the efficiency of the fin"
Would like to know the reasoning ??? Just asking.
Old 03-13-2016, 03:07 PM   #17
TURBS's Avatar
It works and very well I might add!
Don't over think it.
5-10 degree difference.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-13-2016, 03:42 PM   #18
Those interior fans look great against the blue Dometic light. Many don't like them; I love the blue light.
2015 Shamrock 231KSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017, 37 in 2018, 38 in 2019
CNYCamper is offline   Reply With Quote
Old 03-13-2016, 05:10 PM   #19
Hello,
I saw your post about fans in the chimney. How does one do that AND power them?
Thanks,
John
ornery is offline   Reply With Quote
Old 03-13-2016, 05:49 PM   #20
World Wide Wanderer
wahoonc's Avatar
It circulates the air and keeps the fridge box at a constant temp, versus cold air on the bottom and warm air on the top. We did it on a TT a while back and ran an hour meter on the fridge circuit and it reduced the amount of time the element was on by a good 15%. This was at ambient temps in the 70's. I would suspect similar results on LP too.
Aaron
Aaron & Rhonda
electric, gas, refrigerator
