Old 10-06-2013, 07:25 PM   #1
Refrigerator - Gas/power???
Normally use power Just camped at State Park with only 30 amp. Didn't realize not enough to pull frog. Noticed next morning frig had switched to gas. Used gas all w/e. now home and can't get frig to run on power. When press auto button both gas and power lights come on and stay how to get back on power??? I have 50 amp hook-up at home. Thanks for any help or suggestions!!!
Cardinal camper is offline   Reply With Quote
Old 10-09-2013, 07:52 PM   #2
Jimmerinwi's Avatar
It should automatically switch to electric when plugged into shore power. I know in my camper fridge, when the auto button is off, the refer runs continuously.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 10-09-2013, 08:10 PM   #3
Fulltime family RVer
I don't think the fact that you were on a 30amp site has anything to do with your fridge not running on 120v power. I'm betting it was more of a coincidence than anything else. The fridge isn't a terribly high user of power- we had more issues with our water heater kicking on when other high power usage appliances were running. But even then, it would just trip the breaker at the campground box.
UNFORTUNATELY, I have no idea what to tell you that might be wrong. Hopefully someone else comes along with ideas.
ependydad is online now   Reply With Quote
Old 10-09-2013, 09:14 PM   #4
What ependydad said.
The usual things to check like your panel circuit breaker. Plug something else into the outlet that your fridge is plugged into and see if that other thing works. If it does, check the fuses on the circuit board.
Old 10-10-2013, 08:30 PM   #5
Thanks!! I finally realized a GF receptacle had tripped. Reset and worked perfect!!
Old 10-11-2013, 01:13 PM   #6
RPAspey's Avatar
Sometimes the simplest solution is the one overlooked. I've been there.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
