you don't post what make / model inverter you have?
first, just for drill, go to the refrigerator circuit breaker in the distribution panel and trip it an reset it.
we have a xantrex prowatt inverter. it is an inverter only (no converter function) and it does not have an internal bypass relay. there is a separate small transfer relay that the refrigerator is plugged into. this relay switches the refrigerator between between the ac circuit from the distribution panel or the inverter. if you have a similar configuration go rap the side of this relay and see if it is stuck in the inverter position. if you have an inverter with in integral relay see if you can jiggle it.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
