Old 08-13-2016, 06:43 PM   #1
fast murray's Avatar
Refrigerator not Cooling
A friend of mine has a dometic refrigerator in his 2006 All American Sport that quit cooling. I don't know much about these but he says the heating coils get hot to the touch when on auto and it lights the propane burner when on gas but its not cooling. Any ideas or places I can look?
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 08-13-2016, 06:57 PM   #2
If the coils are getting hot, but the fridge is not cooling the cooling unit has sprung a leak and needs to be replaced. Had to replace mine 2 years ago, it was doing what you just described.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 08-13-2016, 07:23 PM   #3
Head Rambler
While the cooling unit is probably bad, I'd check it over real well before I decided to replace it.
Look all up and down the cooling unit for signs of leakage.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-13-2016, 07:48 PM   #4
Georgia Frog Rally 2017
aceinspp's Avatar
Depending where you live there are folks that can repair at half the cost. Did this a few years back. All I had to do was remove and take to them. Lot cheaper than buying new. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-13-2016, 08:08 PM   #5
You may or may not find a leak (yellow in color). With mine there was no indication of a leak.
If you get a pin hole higher up in the coils there will be no indication. The unit will lose it's pressure so the liquid will not condense properly, but will not leak because of the hole being higher up the coils.
2007 Surveyor SV230
cooling, refrigerator
