Old 08-14-2016, 08:11 PM   #1
Refrigerator Not Cooling
I have a 2016 Georgetown RV and the refrigerator is not cooling -- I tried to reset the refrigerator, tried using propane only, and tried using the generator only. Nothing seem to get the refrigerator to start. Any recommendations?
wnishimoto is offline   Reply With Quote
Old 08-14-2016, 08:27 PM   #2
Brand? Model?
Turn it on on the control panel.
Unless it is a residential refer it requires 12VDC before it will operate. So start there with a volt meter.
donniedu is offline   Reply With Quote
Old 08-14-2016, 08:34 PM   #3
Head Rambler
Answer Donnies question first.
Are there any lights on the front panel?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-14-2016, 08:50 PM   #4
Refrigerator Not Working
Yes the light goes on when I select the on button with the Auto cycle however the refrigerator does not get cool.
Old 08-14-2016, 08:55 PM   #5
How long are you waiting. Generally speaking you need to wait 24 hours before loading food. 6 to 8 hours and you should feel the bottom of the freezer section getting cold.
Old 08-16-2016, 08:59 PM   #6
Dazed & Confused
M&K Hoffman's Avatar
Good luck.... I have searched many, many threads here and on other forums and the answers all generally the same and not helpful if you have the same problem I am having. I have a Dometic DM2652LBX refrigerator that I have had problems with it not get cool enough the last three uses. Started Memorial Day week-end running in the low 40's with outside temps mid to upper 80's. Had nearly the same conditions 5 nights in mid July except the refrigerator temps were getting into upper 40's. Just returned from 8 nights at our county fair with daytime temps. mid to upper 80's and night temps low 70's and the refrigerator ran in the upper 50's. Darn good thing there is lots of fair food to consume because we ended up tossing most everything in the refrigerator. Yes I tried it on 120 vac power and on LPG and conditions were identical. Yes trailer was level. Checked the thermistor today and at ~76 degrees it read 3.058K ohms and immersed in ice water for at least 1/2 hour it read 7.07K ohms. Not exactly what the chart calls for, but seems "in the ballpark" and is definitely changing with temp. I just located a test where you disconnect the heater from the circuit board and apply 120 vac directly to the heater. Let it run 10 to 12 hours and if it get cold, it's a control problem.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 08-16-2016, 10:21 PM   #7
My heat element in my DMR 702 ran constant three days and wouldn't cool. Domestic refused to fix under warranty. Apparently is OK to make a box and call it a refrigerator and charge $1500 for it and it doesn't cool anything.
Replaced with residential fridge.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 08-16-2016, 10:27 PM   #8
I've got a Dometic DM2652LBX and it was running like yours. I installed two of these and it performed much better. Air flow is key.
https://www.coolerguys.com/products/...3-speed-switch
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 08-17-2016, 04:41 PM   #9
Refrigerator just stopped cooling help
I am very new to the RV world and my refrigerator just stopped cooling lights on the front are on but nothing have tried both electric and propane no fuses blown any ideas I have a sunseeker motorhome with Domestic fridge
Annb54 is offline   Reply With Quote
Old 08-17-2016, 05:03 PM   #10
Head Rambler
Did you check the fuses on the fridge control board?
There's a hi temp cutout on the side of the flue. It may be the problem.
Gotta go campin!
cooling, refrigerator
