Old 05-27-2019, 08:26 PM   #1
Refrigerator not cooling
2014 Georgetown Rv, Frigidaire french door model not cooling, fan blows light work, control panel works but neither frig nor freezer gets cold. Breakers fuses are ok. Any ideas? Thanks
wilr is offline   Reply With Quote
Old 05-29-2019, 09:37 AM   #2
SeaDog's Avatar
Did you check to see if the compressor is starting? light can come on and fan may run but if the compressor is dead the frig will not cool.
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-29-2019, 09:56 AM   #3
Assuming it is a 120v residential model only?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-29-2019, 10:05 AM   #4
When you say the fan works, which fan do you mean? Does it cool at all...even the slightest.
Feel the plastic "tower" in the back of the fridge and freezer to see if there is any cooling.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-29-2019, 11:40 PM   #5
its either the compressor or the compressor start/stop switch. It is the Frigidaire Gallery the residential model.
Old 05-29-2019, 11:41 PM   #6
fan in the ice maker works. the frig is the frigidaire gallery residential model, French doors.
Old 05-29-2019, 11:43 PM   #7
yes its the 120v residential model Frigidaire gallery
cooling, refrigerator
