Originally Posted by JerseyVic
I actually have the same inverter WFCO 1000 WF-5110HP. No I haven’t taken it apart yet but I guess checking the power at the back where it’s hard wired in is the next step. I know the power is coming out of the breaker. Do you know of anyway of bypassing the inverter? I’m in Florida for the entire winter and really don’t need the inverter till spring. If I could bypass it and the refrigerator starts working on shore power, I’ll know for sure that’s my problem.
Have you looked at the backside of the inverter? There is an ac cord that plugs in to input shore power to the unit. Trace that ac cord back and you should find a receptacle that is is plugged in to. This is the power from the panel breaker. See if this is a gfi receptacle. If it is, make sure it is not tripped.
You can also probe this receptacle with your voltmeter to ensure you have 120 volts present.
If you do have 120 vac and no gfi tripped you could use this receptacle to bypass your inverter. Unplug the inverter from this receptacle. Remove the back plate where the ac out is on the inverter. Remove the wire nuts and add a 3 prong plug to the wire that leaves the inverter. Plug this temp plug into the ac receptacle that fed the inverter.
Are you ac savvy? I’m not trying to be rude but make sure breakers are off and inverter is off before messing with the wiring.
When everything is operating normal you should be able to look at the front panel on your inverter and see status leds and more info on lcd screen.
The following three pics show the following.. sorry about having to get on your head to view them..
First pic inverter off, green led indicates shore power is on and just passing thru, LCD blank.
Second pic, inverter on, green led indicates shore power is on and passing thru, LCD shows the ac voltage being supplied by shore power.
Third pic, inverter on, yellow led indicates no shore power, LCD shows a battery symbol and the ac voltage being generated by the inverter.
If your inverter is off and you have no green led your inverter is not seeing shore power.
