Old 01-15-2019, 06:36 PM   #1
Refrigerator Status?
My refrigerator status light keeps flashing between "35" and "LP." It is set to Auto. Is that normal? What does it mean?
Mark Haffner
2019 Sunseeker 3050 SE
(30' with one long slideout, Ford E450 chassis)
Parkfreeon6th is offline   Reply With Quote
Old 01-15-2019, 07:29 PM   #2
Viet Nam era Navy veteran
Wolf Alaska's Avatar
Mark, there's not enough info in your post unless a reader has the exact same RV as you do. My general advice is that your reefer's display is trying to tell you something is wrong. Guessing the refer is not cooling. Check manual or go on line to mfg's web site or call customer service.
It may be the refer is not lighting off on propane. On automatic, refers will use electricity (120VAC) if it is available & go to propane if it is not. Then, it will try to light the gas burner 3 times and set a warning if it fails to light after those 3 tries. That may or may not be the situation your refer is in now. You need to check it out and become the resident expert on your refer, unless you can get someone else to become that expert. Let's Roll ! Wolf Alaska
Let's Roll !
Wolf Alaska
Fury, Dynamax Freightliner Columbia Grand Sport GT GC400GT
Papa Bear, Jeep Commander Overland
Wolf Alaska is offline   Reply With Quote
Old 01-16-2019, 10:50 AM   #3
Post the make and model of your fridge and we'll be more able to help you. However, I don't remember ever seeing anyone posting a code of 35 before.
Gotta go campin!
Old 01-17-2019, 09:54 PM   #4
Figured it out
The LP supply was interrupted when I turned everythungf off to get gas. I just had to turn it off and back on. The flashing number was the fridge compartment temp.
Mark Haffner
refrigerator
