Mark, there's not enough info in your post unless a reader has the exact same RV as you do. My general advice is that your reefer's display is trying to tell you something is wrong. Guessing the refer is not cooling. Check manual or go on line to mfg's web site or call customer service.
It may be the refer is not lighting off on propane. On automatic, refers will use electricity (120VAC) if it is available & go to propane if it is not. Then, it will try to light the gas burner 3 times and set a warning if it fails to light after those 3 tries. That may or may not be the situation your refer is in now. You need to check it out and become the resident expert on your refer, unless you can get someone else to become that expert. Let's Roll ! Wolf Alaska
Let's Roll !
Wolf Alaska
Fury, Dynamax Freightliner Columbia Grand Sport GT GC400GT
Papa Bear, Jeep Commander Overland
