Old 04-11-2016, 10:39 AM   #11
Maybe try this:
Here's a step-by-step:
http://www.snip-the-tip.com/cgi-bin/articca.cgi
2011 Traverse LT, 3.6L, FWD
Old 04-11-2016, 10:41 AM   #12
Georgia Frog Rally 2018
aceinspp's Avatar
What is the frig in? Never seen one without a being able to set temp. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 04-11-2016, 04:32 PM   #13
OP says 1 1/2 year old Sun Seeker and new thermostat has been put in and has tried adjusting the temperature adjustment slider on the fin.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-13-2016, 08:47 PM   #14
Leaning towards a control board issue and not just a thermistor problem. I don't suppose you know how CW determined it needed a new one and are you sure they replaced it?
As others have posted 36 to 38 in the fridge section is Ideal.
Going to give you a cheat to try, if you are at the bottom of the last fin on the right move the thermistor and holder over two fins toward the left and position the thermistor in the center vertically on the fin. This will make the thermistor react sooner as the fins are cooler the further left you go, that's why you see ice and condensation more on the left. This will cause the refrigerator not to run as long. You may have to make adjustments to get to what ever temperature you are after. This will not have any damaging effect on you refrigerator.
Rich5117 is offline   Reply With Quote
refrigerator
