Old 09-29-2015, 04:36 PM   #11
Is the thermostat the same as the probe/slide on the fin?
UK Cards Fan is offline   Reply With Quote
Old 09-29-2015, 04:44 PM   #12
Jim Schings's Avatar
Freezer temp is fine, 34 or under is a bit cool. I would try moving the slide a bit more before taking to the dealer and they screw it up
Re: HE verses SHE. UK CARDS FAN's come in all flavors. That is why we have an option to fill in the PROFILE. Then we know what part of the country you live in, the type of RV you have, and hopefully your sex..... (or lack thereof)
BTW, What UK CARDS? (University of Ky? We are Cats. Cards are Louisville.)
Jim Schings is offline   Reply With Quote
Old 09-29-2015, 04:49 PM   #13
oldgold's Avatar
Try this.. There is a clip that the temp probe is attached to. Pull it out and put it back in with the very top of it in the clip with the clip as low as you can slide it. Wait a couple hours and see what happens. I had to push mine way up against the ceiling of the fridge to get it cold enough. Maybe you have the opposite problem.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 09-29-2015, 04:52 PM   #14
Well aware of diff. Born and raised in KY and HUGE UK fan. But now live in St. Louis and a HUGE Cardinals baseball fan. Only two sports I need. NCAA playoffs and World Series takes the entire year!
Old 09-29-2015, 04:53 PM   #15
oldgold's Avatar
I though you liked English Greeting Cards.. Lmao
Old 09-29-2015, 04:58 PM   #16
Did that. Took it completely off, wiped it off, stuck the probe back in, all the way up in the clip, and then tried adjusting it. Pull the probe down, every which way over two trips of 17 days total. Each time, giving it a chance before changing again. Usually overnight.
Old 09-29-2015, 04:59 PM   #17
Talley Ho
Old 09-29-2015, 05:04 PM   #18
oldgold's Avatar
What about out of the clip completely and hanging down? That low?
Old 09-29-2015, 05:07 PM   #19
I do have a profile.
Old 09-29-2015, 05:07 PM   #20
oldgold's Avatar
It just shows your name and member since info. No other info shows up.
refrigerator
