Old 01-10-2015, 10:33 PM   #1
refrigerator won't power on
Tried to start the dometic 2852 refrigerator today while connected to 110. When I pressed the on/off button, I could hear a solenoid click, the light inside the fridge came on and the check light flashed. When I let go of the on/off button, the everything shut off.
I have 12 volts coming into the rear compartment, the 2 fuses in the control module were good, and the in-line fuse was good.
Any thoughts?
brianzie is offline   Reply With Quote
Old 01-12-2015, 11:13 AM   #2
Does it work on propane??
The frig uses 12VDC for the control circuit and 110VAC for the frig heater when plugged in. If it works on propane but not electric the heating element may be bad.
cadman99 is offline   Reply With Quote
power, refrigerator
