Old 02-01-2017, 09:19 PM   #1
Toy-aholic
Remote fridge operation.
I would like to be able to turn my fridge (elect.) on from home hours before we leave to go to our seasonal site. My question is has anyone used those "smart outlets" avail. from various sources and would it work to do this?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 02-01-2017, 09:27 PM   #2
I'm intrested to see responses. I was not aware of a "smart outlet"?
If it a seasonal spot why not leave the fridge on with condiments and such in it? Why turn off all the time? Air conditioning yes for sure. But if the camper is plugged into power why turn fridge off?
Kimber45 is offline   Reply With Quote
Old 02-01-2017, 09:33 PM   #3
Toy-aholic
We did that last yr. & got a wopper of an elect. bill. So we run fridge & water heater on gas. I just want to get it chilled down until we get there to switch it over.
Old 02-01-2017, 11:37 PM   #4
I think what will happen is the fridge would go into lockout.
If it is set to auto (AC/Gas) and there is no AC present it will switch to propane mode. It will try and light (with propane) 3 times then lockout. At that point it will not operate in AC mode or Propane mode until it is manually reset (turned off then back on).
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 02-13-2017, 11:05 PM   #5
Kirk S's Avatar
As far as I know, smart outlets need a wi-fi connection to operate remotely, as in via the internet. If you have reliable wi-fi at this seasonal spot it should be possible but may be expensive. I've seen the Nest systems at Home Depot but surely you can Google smart outlets to learn more.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
fridge, remote
