Old 02-10-2017, 12:40 PM   #1
Removal of Genesis 2.0 faceplate
Sorry if this is a duplication...
My Genesis GT2.0 has three speaker buttons (A,B,C). Apparently, the factory wired my outdoor speakers so that they are on all the time. Not good for neighbors.
I suppose I can correct this on the rear of the unit. But I find the unit's faceplate is flush against cabinet. I don't know how to get access to the mounting screws. Does the faceplate pry off? Looks like vinyl or plastic, but I don't want to break anything, obviously.
Any suggestions will be appreciated.
TacBear
TacBear is offline   Reply With Quote
Old 02-10-2017, 12:59 PM   #2
Flybob's Avatar
The bexel should pry off. Then there should be 4 screws.There are small tabs around the perimeter that hold it on. Use a thin screwdriver and carefully pry out and away from wall. You should see a spot in the bezel where you can start the screwdriver.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
