I'm not sure if this is the correct thread in which to post this question, so I would humbly request that the forum administrator move it to the correct thread if applicable.
Does anyone know the trick to removing the drawers from there slides? Here's a picture of the slide.
Just push up or down, whichever side you are pushing, on the black tab sticking out to the front. Will be one on each side and they move opposite of each other I believe. Then pull out drawer as you are doing this.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
You will notice a black tab on each of the slides. They are located in the channel of the slide and will be accessible when you extend the drawer. You can see them in your third picture. Long black tab. Either push them up or down (one side you will need to push up while the other side you will need to push down) while pulling on the drawer. This will allow you to remove the drawer.
Hope this helps
Bill and Diane Hanton
Cobalt, Ont
2011 Greywolf 18RB
2015 Ram Ecodiesel
Equalizer hitch
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
Thanks a bunch...worked like a charm. The trick was to push down on one tab and pull-up on the other at the same time. That was the part that had me baffled!
