Old 05-02-2013, 05:22 PM   #1
Steve Jackson
sideout1961's Avatar
Removing TV from wall mount
Can anyone help me? I am trying to remove the TV from the entertainment center and can't seem to figure out how to get it off the wall mount. There is absolutely no room to see around the sides. I want to gain access to the HDMI ports for my Roku player.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 05-02-2013, 05:29 PM   #2
rattleNsmoke's Avatar
The flat-mount on my Cedar Creek has 2 allen set screws, (one on each side) that can be reached with the supplied reeeeally long allen wrench or an allen\socket with a long 3/8" extension. If you can't see back there, try using a flashlight and mirror. That's how i first found mine. Good luck.
rattleNsmoke is offline   Reply With Quote
Old 05-02-2013, 05:31 PM   #3
Steve Jackson
It's going to be a tough one if that's the case I can hardly fit my hand around the boarders let alone a tool. And I didn't receive any Allen wrench.
Old 05-02-2013, 06:05 PM   #4
Campfire Master
Lift up. You may have to wiggle it back and forth a little.
John
AVid is offline   Reply With Quote
Old 05-02-2013, 06:08 PM   #5
sherri330's Avatar
We have to push in while lifting up on ours. Good luck!
sherri330 is offline   Reply With Quote
Old 05-02-2013, 06:26 PM   #6
Camping Buddys's Avatar
Don't know about your trailer tv, but in ours is a jensen tv mount and it was a pain to remove the tv. I replaced with a extend one.
The mount have a tumb lock on top, you need to push that back and lift the tv and it should work. Hope this help!
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 05-02-2013, 06:38 PM   #7
Oaklevel's Avatar
Don't know about yours but our Puma has a swing arm. There was a pin that keeps it closed on the right side. It was a bear to get it loose the first time.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-02-2013, 07:02 PM   #8
Steve Jackson
I did feel a metal tab toward the top of TV. I will try pushing that. It's just really hard I can barely get my hand in there. They really have the TV planted right up against the wall.
Old 05-02-2013, 07:57 PM   #9
outdoor addict
My TV's both are hard mounted on plates that are fastened to the walls with a number of screws.
Norm
nakerr is offline   Reply With Quote
Old 05-03-2013, 10:47 AM   #10
I had the same issue with the two TVs in my 2012 V-Cross fiver, the service department at the dealer were I bought it was no help at all, they said " there are a lot of different types of mountings". There are two small chains on each TV and you pull both chains down and pull out the bottom a little and lift up. Good Luck
whj77372 is offline   Reply With Quote
