Old 07-11-2015, 09:10 AM   #1
Repairing furnace wiring
I blew a tire on my 2007 Wildcat, and the steel belt whipped around and tore out the wiring to the furnace. I can't get to the wiring (at the rear of the furnace) to repair it. I'm wondering if the floor of the fridge compartment can be removed if I remove the fridge. This would give me the access I need.
I hate to remove the fridge only to find the floor cannot be easily removed.
Thanks,
Joe
Coloradjoe is offline   Reply With Quote
Old 07-11-2015, 12:15 PM   #2
Crockett's Avatar
usually just pull the furnace. is it a hydroflame or suburban? exterior door panel or just a vent? that might afford you more access to repair the fender well. havent pulled the refer yet to do one of these and Ive done a few...
Crockett is offline   Reply With Quote
Old 07-11-2015, 12:24 PM   #3
More info
If there were a vent door, it would be easy to access.
It appears the only way to get to the wires is to remove the fridge floor or go in through the bottom of the rv. I'd prefer the former, if possible.
furnace, repair, wiring
