Old 11-18-2011, 11:07 AM   #1
replacement for concertone
Wondering what brands and models of stereos you folks have used when replacing the original equipment..We dont need it to do anything fancy, just good sound. Thanks
blue eyes is offline   Reply With Quote
Old 11-18-2011, 03:13 PM   #2
bikendan's Avatar
the only other common brand is Jensen. there are a handful of RV entertainment system manufacturers.
Jensen is the most common and i guess Concertone is second.
if you have a tall Concertone unit, Jensen doesn't make anything similar in dimensions.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-18-2011, 03:51 PM   #3
Go online to a retailer like Crutchfield.com and nose around.
A double din car stereo should just about fit. They are plentiful, cheap and depending on the features you want should do the job just fine. If it is still too small, a piece of 1/4 inch oak plywood cut and stained to match should fill the void easily.
Old 11-22-2011, 12:45 PM   #4
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Actually a double din will not come close to filling the hole. You will definitely need to build a trim panel to cover for any of the factory installed options.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 11-22-2011, 12:56 PM   #5
camper_Lucy's Avatar
Look for a Marine receiver, there are some that have the larger front plate and will come close to covering the hole if not exceed it. You will find better quality brands as well. Otherwise the only other option I know of would be a Jensen. Good luck
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 11-23-2011, 11:28 AM   #6
thanks for all the suggestions, I will start my search....trimming out the unit isnt an issue,,can always find something that looks good to fill the void,,,I appreciate the replies..Happy Thanksgiving to all...
Old 11-23-2011, 08:40 PM   #7
Anacortesians
I don't know how unusual my '02 GT 325 is, but all the entertainment system on mine (in-dash radio and both TVs) are Daewoo. They don't make consumer electronics any more!
If anything happens to the in-dash radio, I guess I'm off to Crutchfield, or maybe Best Buy. We already took out the bedroom TV and we might buy a cheapy small LCD 16:9 display for the front. Costco has some odd brand 19-incher for $100. We can make it into a door for the overhead cabinet to give us more storage we don't need!
Frank and Eileen
No longer RVers or FR owners
