Old 07-28-2016, 01:00 PM   #1
Question Replacing Jensen TV in 2015 Hemi 272RLIS
Has anyone replaced the Jensen TV with another brand? Wondering if swivel mount will line up. Want to be able to connect a sound Bar and also remote Headset. Can't seem to do that with the Jensen.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 07-28-2016, 01:34 PM   #2
TV wall mounts bolt patterns are in a square pattern. Its measurement will be from one bolt hole horizontally to the other, by vertically to the third bolt.
For example 100 mm x 100 mm, 200 mm x 200 mm etc.
If your mount only has 4 screw holes in it, you are pretty much restricted to finding a TV with the same bolt pattern. It will be listed in the specifications.
If your mount has multiple bolt hole patterns, measure them, this will let you know what mounting bolt patterns you have available when shopping for a TV.
Hope this helps, Sherman
ShermanD is offline   Reply With Quote
jensen
