08-15-2018, 01:12 AM
#21
Originally Posted by Admiral
what is the PDI?
Pre Delivery Inspection or the Walkthrough.
08-15-2018, 06:47 AM
#22
Yes everything worked at PDI........we have had the Rv for one year in June. They had the 2018 models when we bought it.
08-15-2018, 07:25 AM
#23
likely the inverter is there ONLY for the residential fridge, as it's not large enough for much else... I would suspect that your inverter is either not ON, it's own fuse has popped/blown on the unit itself, or there is a loose wire connection at the inverter or into the breaker for the fridge.
The Turners...
08-15-2018, 07:49 AM
#24
The inverter is on , the led is lit up.
08-15-2018, 07:52 AM
#25
Your fridge will be plugged in... somewhere. Try unplugging it and plugging something else on to see if that works. Process of elimination.
#26
even if it's 'on', the fuse could still be tripped/popped...look on the rear of the unit itself, just in case.
08-15-2018, 07:53 AM
#27
Ok I will do that .........thanks
08-15-2018, 07:54 AM
#28
Coach
Think you should locate that fridge outlet and test to see if there is power to the outlet and it is plugged in securely. If there is power to the outlet, then you have a problem with the fridge itself.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
08-15-2018, 07:56 AM
#29
Ok, I will try to find it, just hoping i dont have to pull the fridge to get to it......Someone said maybe behind drawer or something
08-15-2018, 07:59 AM
#30
it's doubtful that the outlet for the fridge would be 'behind' the fridge itself, but more than likely within a cabinet nearby.... ours is under the sink area in the bathroom next door, same place the ice maker line and cutoff is.
08-15-2018, 08:02 AM
#31
the plug will be accessible without moving the fridge. Look for storage under the fridge. look for plug-in cab. next to fridge.
08-15-2018, 08:03 AM
#32
did you look on the back if the inverter?
08-15-2018, 08:38 AM
#33
Ok, checked inverter its on, led reads no problems, connections are tight. Fridge is in slide out so cant go to the right to find anything, and to the left is a cabinet but inside the cabinet is 2 connections that plug into each other, and im assuming run to the inverter. Still no sign of the outlet although i can see part of the cord at the back under fridge. those connections in cabinet were tight
08-15-2018, 08:39 AM
#34
Also reset on converter is not tripped, and no fuse on it.
08-15-2018, 08:44 AM
#35
There is no access under the fridge unless i take the wood apart.
08-15-2018, 08:51 AM
#36
Heritage Glen 337BAR 2018 if you want to look it up
08-15-2018, 08:52 AM
#37
08-15-2018, 09:06 AM
#38
I know you’re frustrated at this point but can you follow the wire from the rear of the inverter to see where it goes?
08-15-2018, 09:25 AM
#39
i looked up your inverter. it is hardwired and it has the transfer switch internal to it. there is no output receptacle on the inverter itself.
i do not know where the receptacle that the refrigerator plugs into is. but you say the refrigerator is in a slide out. can you go under the slide out and find the power cable? look up to where it enters the floor of the slide out. my guess is that the receptacle in inside the slide out just above where it comes through the floor.
if you can find the receptacle try to unplug the refrigerator and plug it into an extension cord to see if the refrigerator runs with know good power. pray it does!
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
08-15-2018, 12:03 PM
#40
Yes I can see wires going up thru floor where fridge is but I can see no outlet. Also wires from rear of inverter go to where it connects in cabinet next to fridge.
