Originally Posted by The Newsoms
Went to the camper today to start trouble shooting. The best I could tell, it was that one leg that was out but the problem was in the female end of the 50amp extension. I heard it give a little “pop” when I moved it and heard the microwave come on. Took the extension out of the equation and all is good. Thanks for the responses. I’ve made a list of the suggestions for future reference.
Sounds like it was either not fully engaged with the main cord or the contacts have arced and are damaged inside that female socket. If it's #2, you should be able to cut off the existing female socket and replace it with a new one and save the expense of a new cord.
To prevent arcing which can damage the connectors in the cord, you need to plug into a dead outlet (ie, no power), and then apply power once the cord is fully seated. Most of us do this at RV parks, but not so much at home. Usually the breaker for a home outlet is no where near where the outlet is.
Another way to prevent arcing is to use the EMS which has a delay, or just flip the main AC breaker to off inside the trailer. Once connected flip it back on.
