Old 08-10-2016, 10:04 PM   #1
Residential refrigerator
2016 sandpiper 5th wheel. After 9 mos on the learning curve i have questions about our residential refer. It seems like while on the inverter, I don't think it's on. No lights and ice is melting. Also, how do you keep the doors secured while on the road?
oldrls is offline   Reply With Quote
Old 08-10-2016, 10:07 PM   #2
It should be running when the inverter is on. Can't help you there.
As for the doors, we use two zip ties each time we hit the road. That knob gadget they gave ain't worth a flip. Two zip ties around the handles when we leave and we just cut them when we arrive. Works like a charm.
2015 F350 6.7L Lariat CC LB
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 08-10-2016, 10:14 PM   #3
What inverter do you have? I have a WFCO-5100. Check the output AC fuse. Here is a link to my models manual. If not the same just google your model number.. http://wfcoelectronics.com/wp-conten...00-Manual1.pdf
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 08-11-2016, 09:03 AM   #4
head gamez's Avatar
Does the light on the inverter switch (in the cabinet) come on? If not....
Look in the basement compartment front wall. There is a switch there that looks like a battery disconnect. It is the inverter power switch. Make sure it is on. If it is not on, then the inverter will not turn of regardless of the switch in the cabinet.
It could also be that the inverter is wired to the wrong circuit. Does the microwave have power when the inverter is on?
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 08-12-2016, 10:35 AM   #5
Sorry for my slow response. I love the zip tie idea, it is hard to believe that they are needed. Without them, I've arrived at our destination to find most of our food spilled all over the coach! I am researching the inverter issues now.
Old 08-12-2016, 10:40 AM   #6
head gamez's Avatar
Sorry. I forgot to address the doors. If you have the LG frdge with the bottom drawer freezer, then zip ties might not work.
I picked up some of the severe duty Velcro and placed a small square above each door on the body of the fridge and a small square on the top of each door. I use the other portion to connect the two. On the freezer drawer, same thing except I place a square on each side.
This stuff has quite a high shear strength so I have had no issues. It is also almost clear, so hard to see when you are setup. FYI. It is not the standard hook and loop stuff. Maybe two pieces mesh together by pressing them, and it holds!
Ill snap a picture later.
2500HD Chevrolet
Old 08-12-2016, 10:47 AM   #7
ours has a couple of little hardware loops in the molding on each side of the refrigerator that allow you to run bungee cords across the refrigerator doors and bottom freezer drawer. it works!
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-12-2016, 12:35 PM   #8
This is what I do, I have long straps Click image for larger version
Name:	ImageUploadedByForest River Forums1471023314.705094.jpg
ID:	117012Click image for larger version
Name:	ImageUploadedByForest River Forums1471023329.426053.jpg
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-16-2017, 09:21 PM   #9
Residential frig on the inverter
Ok, I am hoping for an answer. When on the inverter, my residential refrigerator does not appear to be working. No lights. I have not attempted dry camping so can't prove it isn't working. Inverter light is lit. Of course it's beyond warranty.
2016 Sandpiper 5er.
Old 02-16-2017, 09:44 PM   #10
2016 Sandpiper 5er.
The light inside should turn on when you open the door. It should operate the same and look the same as when operating off of shore power.
Does it light on ac power?
2016 Siverback 33IK
refrigerator
