I'm not familiar with the cable wiring of the Rev, but have worked on Sunseeker models. In the Sunseeker there is a satellite jack inside one of the cabinets, and that cable terminates on the roof (not much help for a Tailgater). The cable input on the side of the coach likely goes to an antenna booster with an on/off button switch and a single connection jack, with off being cable and on being OTA antenna. If this is your setup, then the current wiring on the side of the coach will not support satellite without modification. See this discussion thread:
http://www.forestriverforums.com/for...te-120160.html
