Old 08-06-2013, 09:09 PM   #1
Reverse RV-Wingman Installation
We have a new Forester 3051S MH and the TV reception while camping has been marginal at best. The RV-Wing add-on does not fit since there is less than 3" of clearance to the fridge vent on the roof (need at least 10" clearance). You would think that FR would locate the antenna so that common add-ons could be used, but they didn't!
There isn't much info on the internet about reversing the antenna, and Winegard says it can't be done. For anyone who's interested, I was able to reverse the antenna head so the the RV-wing has suitable clearance. Photos are attached. I used two 3" 1/4-20 ss cap screws with nylon washers, 1' nylon spacers, and ss 1/4-20 lock nuts. I had to drill two 1/4" holes in the plastic mounting bracket (be sure to replicate the original holes and drill perpendicular.
ID:	37106   Click image for larger version
ID:	37107   Click image for larger version
ID:	37108   Click image for larger version
ID:	37109   Click image for larger version
dcogs15 is offline   Reply With Quote
Old 08-06-2013, 09:22 PM   #2
B and B's Avatar
Nice work!
B and B
Old 08-06-2013, 10:23 PM   #3
Replaced mine with a JACK antenna- works MUCH better. AND yes, I also had the wingman add on, it helped some, but the JACK antenna still works better, in my opinion. Randy
Old 08-06-2013, 10:43 PM   #4
B and B's Avatar
I also have installed a Jack as well, can not speak for a Wingman. One thing to look at is antenna splitter loss. Many splitters are designed for cable and have lots of loss, 7 db in some cases. Replace with a 3.5 db loss and you get double the signal.
B
B and B
Old 08-14-2013, 08:27 PM   #5
phat phrog stunt crew
where would this splitter be located? we have a 31 rets6 with lousy tv reception. by lousy, i mean the ability to pick up many tv stations.
dwaynerz is offline   Reply With Quote
Old 08-15-2013, 07:41 AM   #6
B and B's Avatar
Dwaynerz,
The splitter in my unit 8289ws is behind the Genesis radio, that is same spot were the antenna amp switch is located. In my travel trailer the pop up tv had a wall with all items mounted on it.
Brian
B and B
Old 08-15-2013, 04:33 PM   #7
thanks b and b. will look next time trailer is at home. have wondered about the jackman(?) antenna, but it looks to be a fixed mast type. just one more thing sticking up on the roof i have to worry about getting removed by a limb, sign, bridge (insert other low object here).
