Old 10-18-2018, 03:54 PM   #1
RangeMaggotBob's Avatar
RG6 Cable
Has anybody used this?
Quad-Shield RG11 Heavy Duty Coax Cable w/ Weather Boot Connectors Indoor/Outdoor
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 10-18-2018, 03:57 PM   #2
For what exactly? Satellite?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 10-18-2018, 04:30 PM   #3
B and B's Avatar
Less loss with RG 11. I doubt for a RV you will require this though as most runs are less than 100 ft or 31.5 meters. Hardly worth it for a db or two.
Old 10-18-2018, 04:30 PM   #4
Yes, ISP's use it in their headends, why are you looking to use that?
wildcatter is offline   Reply With Quote
Old 10-19-2018, 04:09 PM   #5
No line loss. It has weatherproof Belden connectors to limit interference from the weather, nickel and anti-corrosion materials, UL listed, 14 AWG solid copper core @ 3Gigahertz, 75 ohm.
I have been having problems with my satellite setup, and this is the last thing to replace. We camp in a lot of places where we need 100' to get to a place with a clear view. Hoping this helps solve my issues. And also hoping to never buy another cable! I was just wondering if anybody else has used this cable. Thanks for the replies!
Old 10-19-2018, 05:23 PM   #6
I wouldn't use RG11for home or R/V use. You'll never see an advantage in runs of less than 100+ feet. It's harder to bend, slightly larger in diameter and more expensive. If you already have some (and the fittings) well then...
Days Camped: '16=46 '17=30 '18=51 '19=18
Old 10-28-2018, 06:36 PM   #7
UPDATE- best cable I have ever used! Heavy duty, rolls up nicely to fit in a small tote, and fixed any issues I was having. Completely water proof, and worth every penny of the $48.00, plus had it in 3 days.
cable
