Old 10-30-2013, 10:48 AM   #1
Rockwood 5th wheel TV connections
Finally I found a place where I can ask this stupid question :-) . . .
In my Rockwood 5th wheel, there is a TV jack in the bedroom..... Where does that go to? The outside antenna? or does it go to a plug in the living room or ? I havent had the time to try and figure this out, I appreciate any help.
THanks everyone,
Rod
rodinbigbear is offline   Reply With Quote
Old 10-30-2013, 11:14 AM   #2
It goes to the back of the antenna booster control plate. (It may go thru a splitter to get there if you have more than 2 total TV outlets in your RV.) It will deliver either off-the-air TV or "Park Cable" depending on whether you've turned the booster off or on using the push button.
Old 10-30-2013, 11:37 AM   #3
Just to be straight
So, whatever input my "main" TV is connected to, my "second" TV will also be connected to the same input?
Thanks,,,, Rod
Old 10-30-2013, 02:13 PM   #4
Yes
Old 10-30-2013, 02:23 PM   #5
dcheatwood's Avatar
Correct. And you may have another connection inside your curb side storage door. Depending on model you have.
2018 Forester 3011 DS
5th wheel, rockwood, wheel
