Old 07-26-2013, 07:57 PM   #1
Night Stone's Avatar
Roof radio antenna
I was wondering if anyone has one on their trailer and replaced it with a better one which that does not stick upwards? Does this antenna unscrew as I want to put a cover over my trailer
I am not referring to my wingman antenna, as that one uses a crank to fold down
Dave
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 07-27-2013, 02:33 PM   #2
Smile
Dave
The antenna base has a phillips head screw. Loosen and rotate antenna down. The antenna on my TT collides with the Winegard crankup antenna. They actually get interwined and cause the crank antenna to lock into an upward position and you have to separate the antennas to lower the Winegard. I have a 14 inch "rubber ducky" style antenna and base that I am about to install. Cost all of $22.00 shipped to me. Has a built-in amplifier. Amazon.com has some available. I do not anticipate any major reduction in signal strength. Time will tell. Beats climbing onto the roof to separate the antennas. You can also lower the stock radio antenna to avoid antenna interlocking!
l001952119 is offline   Reply With Quote
antenna, radio, roo, roof
