So you won't be to disappointed, typically "Satellite Ready" means a coax cable has been routed to somewhere on your roof from where a receiver might be installed inside the rv. There also may be a power wire. The coax, typically, will not have a connector at the roof location. It will be coiled up. Sometimes the coax location on the roof is marked ("X", dummy vent cover, etc.) and sometimes it's not. Someone with a unit like yours will probably chime in. The install using this coax would be a permanent type install. If your antenna is a carryout this most likely would not be the interconnect location for that type of antenna. As said, this is a typical scenario. Of course, there doesn't seem to be to not many things typical about FR RV's when it comes to electrical.
