Old 09-07-2019, 10:12 AM   #1
chuck9997's Avatar
Running AC at home on regular house current
I have never done this.. and I know there are differing opinions. But.. does anyone here run their RV air conditioner while hooked up at home on the regular house current? I have always kept my camper plugged in at home.. and usually keep the fridge on.. but I don't run the AC.
What is your experience?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 09-07-2019, 10:19 AM   #2
Blackrock's Avatar
I have a 30amp box, water and a sewer drop at home. Works real well for when the kids come to visit.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 09-07-2019, 10:26 AM   #3
Using a 100 extension cord and a 15 amp circuit you are close.
Typically the converter, fridge and ac are running. Pretty max.
Make sure the second ac is switched off.
tomkatb is offline   Reply With Quote
Old 09-07-2019, 10:37 AM   #4
frank4711's Avatar
Yep... we have a 50 amp hook up ... we do not run frig but we keep one A/C at 88 keeps camper dry .... central Fl has way to much humidity ... Thanks Frank
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 32 days camped 2019 *** Predator 3500
frank4711 is online now   Reply With Quote
Old 09-07-2019, 11:09 AM   #5
Have a 50 amp box, water, and sewage, everything stays on. Ready to use on a moments notice, don't want to miss a chance to go camping! 🤣 We also use it as a second kitchen or bedroom if needed.
wtbuck12 is online now   Reply With Quote
Old 09-07-2019, 11:50 AM   #6
bikendan's Avatar
I've done it with both my trailers, for the past 14 years. Just used a 30-20 amp adapter.
Equalizer WDH
Old 09-07-2019, 11:59 AM   #7
I do turn AC on when need and it's always plugged up but AC will not be on unless someone needs it. My power company has enough of my money they don't need it all!!
cfo111 is offline   Reply With Quote
Old 09-07-2019, 01:23 PM   #8
OldJarHead's Avatar
X2
2015 RAM 3500 Cummins LB 4x4
2018 Rockwood Signature Ultra Lite 8328BS
OldJarHead is offline   Reply With Quote
Old 09-07-2019, 01:30 PM   #9
I have a 30A outlet at home so I haven't experienced any problems. I have run it on my 3500 watt inverter generator as well with no problems. The typical rv a.c. unit draws about 14.5 amps and your standard outlet in most home is 15 amps. If you had nothing else running on that circuit, you would have just enough.
2018 Grand Cherokee 3.6
2018 Prime Time Tracer 20RBS
corky310 is offline   Reply With Quote
Old 09-07-2019, 01:38 PM   #10
Good article
Is It OK To Run My RVs Air Conditioner When Plugged Into House Electricity?
Old 09-07-2019, 01:49 PM   #11
Old Forester's Avatar
I'm a total believer in running one or the other A/Cs in our Windjammer 3029. I put in a 60-amp 220v box on the outside of the garage and here in Louisiana, I'll set it at 80. I monitor it with an RF ThermPro Indoor Outdoor Temp/Humidity gizzmo sitting on kitchen counter and 100-feet away through 3 interior and one brick wall. I love how it keeps it around 35-40% RH inside. You have to be sure to clean the roof units after the annual pollen dump. In the winter, I run a dedicated Dehumidifier that drains to the outside through a small diameter hose.
Old Forester is offline   Reply With Quote
Old 09-07-2019, 02:04 PM   #12
Mr. Dan's Avatar
I don't think this is what the OP meant by "regular house current".
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-07-2019, 02:08 PM   #13
lazyjj's Avatar
Have 50amp and home. 92 degree day today and both AC units are currently running. Even parked under shed.
lazyjj is offline   Reply With Quote
Old 09-07-2019, 02:13 PM   #14
Only is you have the AMPS needed
If you have the power... else you will pop your circuit breaker. I have an EV charger for my two electric cars and use that to power my RV.
tmsimmons56 is offline   Reply With Quote
Old 09-07-2019, 02:50 PM   #15
I have a 30amp circuit for my class c which I plug in at home. No different than being plugged in at an RV park.
Luke Moseley is offline   Reply With Quote
Old 09-07-2019, 03:36 PM   #16
What are you describing as 'regular house current'?
The current at your house is no different than any other current in the USA.
The voltage/amperage of the connection may be different but not the current.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-07-2019, 03:37 PM   #17
Villagerjjm's Avatar
I have a 20 amp breaker on a standard outdoor outlet that I will plug into using a 20amp to household outlet adapter. I live in Florida, so I run the AC quite a bit. Never had any problems.
Villagerjjm is offline   Reply With Quote
Old 09-07-2019, 04:42 PM   #18
HHmmm, anybody besides me notice how the title of this post has changed? From no mention of house current in the title, Running AC At Home , to "Running AC at home in regular house current",, to now the "in" has been switched to "on"... Something in Denmark smelleth.........
Old 09-07-2019, 05:14 PM   #19
Thinking the title has changed because of so many different answers. Like Mr.Dan, I believe the OP is refering to a standard 15A electrical outlet at his home. Not a 50A, not a 30A, but just a good old 15A. You can do it, but when I did it, the cord and plug always got pretty warm...almost to HOT side of things when I ran the AC. Most times it tripped the breaker quite easily. That's when I installed a 30A in garage to plug TT into.
TheWolfPaq82 is online now   Reply With Quote
Old 09-07-2019, 06:50 PM   #20
Don't Camp Enough
DSMURPHY's Avatar
X2
'2016 Rockwood 8288WSA
'2016 F-350
DSMURPHY is offline   Reply With Quote
