Old 10-28-2013, 07:43 PM   #1
running lights on with shore power and with battery
2006 Wild Wood 26 ft TT: It just started happening. When I plug in the shore power, the running lights come on. The same with the battery. I have disconnected the battery and am leaving the trailer unplugged. I have gone through the fuse box and tightened everything. I have no wires haning anywhere. I bought it used. I have looked everywhere to see if the original owner rigged a switch somewhere to have the running lights come on while camping. The plug to the truck does not have any thing rigged like some folks do. We went from Michigan to Yellowstone, Glacier and back without a problem. This is all since we have been back. I feel that I have a short, or a gremlin somewhere, but how does one get to look at all the wires for inspection? Help!! Does anyone have any ideas because I just dont know what to do.
Sidefx
sidefx is offline   Reply With Quote
Old 10-28-2013, 07:47 PM   #2
Buddy Duncan's Avatar
I was once shown that if you put a plug fuse between the top 2 pins on your trailer plug, the one you plug into your TV, it will allow your running lights to be on while you're plugged into shore power. The previous owner may have installed something on those 2 lines near the battery.
Buddy Duncan is offline   Reply With Quote
Old 10-28-2013, 08:18 PM   #3
I think my first check would be the wiring going to the tow vehicle. It is subject to the most flexing and abrasion. If it gets shorted it could cause this problem. The problem almost has to be in this run and I can't envision any cause not having to do with tow connection. Good luck and keep us posted.
Timtation is offline   Reply With Quote
Old 10-28-2013, 09:14 PM   #4
raspivey's Avatar
Any way you look at it, the tail light wire is making contact with the hot / charging wire between the truck and trailer. I'm willing to be it's shorted in the pigtail plug. That, or something has pinched that harness (most likely between the frame and the hitch).
Old 10-29-2013, 02:59 PM   #5
This is with the truck NOT hooked up and plugged in. I checked the plug and wire and did not observe any pinch. I will give it a closer inspection. If it is not in the pigtail, where do I go from there? Thanks for the suggestions, Guys.
Old 10-29-2013, 03:21 PM   #6
Go to the junction box at the trailer where the pigtail enters the trailer. As stated, there has to be a connection between the charge wire or another 12v hot wire and the running lights or a hidden switch the original owner wired in and you inadvertently flipped.
Old 10-29-2013, 03:24 PM   #7
wmtire's Avatar
Have you replaced the RV battery recently or did anything where it was disconnected and the wires could have been crossed?
I'm just thinking aloud in case you're powering the negative wire.
WARNING: DO NOT just arbitrarily switch the wires to test, as you will blow the reverse polarity fuses to your converter. You may have it all correct to begin with.
2011 Flagstaff 831 RLBSS
Did you know, according to Google: Pepsi was once the 6th largest military in the world?
Old 10-29-2013, 03:30 PM   #8
Witch Doctor's Avatar
Check to see if you have condudity in your trailer plug anywhere(disconnect the battery first), go to ground I think that should be the center you can find that on the web under 7 wire pig tail. You will have too try each slot. If you are trace it back to where it all ties in and look for a short. Also go to ground on your trailer and test each slot and see if you are getting 12v anywhere ( with the battery on). Match to the wire diagram that will show you what each leg controls. if the hot is touching that wire or shorted it will bring them on. Just like the fuse trick mentioned above.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 10-29-2013, 03:57 PM   #9
wmtire's Avatar
I forgot about that Buddy, good suggestion. Besides running a jumper wire in the plug, some people also wire a switch inside the RV to accomplish this. Have you flicked any unknown switches on inside (or even outside) the RV as Buddy pointed out?
They even make a product to do this for you:
RV Glow - Turn your outside camper lights into patio lights.
Old 10-31-2013, 10:23 PM   #10
I looked hi and low for a switch. nada. I know that the battery wires are where they are supposed to be. Now, somewhere I havnt looked is right on the front of the trailer, there is a door. I would have to move the gas bottles to get the door open. I believe that is where the hydrolics are for the slider. I wonder if the pigtail comes up into that box? I will check it out and let you Boys know. I know that it is something weird going on. It was parked in the driveway for a month or 2 before this happened, so there was no new movement or anything. It just happened, then it quit for a week, now it is full time.
battery, light, power
