Old 09-14-2014, 10:12 AM   #11
RSchleder's Avatar
Originally Posted by Backcountry View Post
I am under the impression that there is an advantage to HDMI if the device upscales the DVD signal to the native resolution of the TV. Either way, seems a little silly I should have to spend $20 bucks on a converter.
Not sure what all that means, however, how would the "device" know the native resolution of a particular TV as there is no feedback signal from the TV to the "device". You either have a 720/1080p signal (HD) coming from the DVD player or you do not. HDMI transmits all signals, 480/720/1080 in the exact configuration it is given by the "device" transmitting it.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 09-14-2014, 11:56 AM   #12
This article offers a good explanation. Most modern DVD players upscale to both 720 and 1080 and your TV will process the best fit resolution coming out of the DVD player. An RCA composite connection is incapable of passing the upscaled signal to the television, and therefore the signal being displayed on your TV will be 480p (standard def) rather than high def (720/1080p).
Depending on the quality of the upscaling processor on the DVD player, there can be a big difference in quality between an unprocessed 480p signal and an upscaled 720 or 1080p signal on an HDTV.
Backcountry is offline   Reply With Quote
Old 09-15-2014, 08:06 AM   #13
Herk7769's Avatar
Lots of "new to me" information here that may or may not be true.
My understanding is as follows:
DVD player output equipped with:
HDMI - required to get the maximum 1080p signal from "any" DVD player to a similarly equipped TV. Required for Surround Sound output to TV IF TV is Surround decoder equipped. Capable of transmitting lesser resolutions being sent from DVD player.
COMPONENT (3 RCA video-2 RCA audio) - 1080i or less ONLY; provided similarly equipped TV - Analog audio only (No Surround Sound) to TV
COMPOSITE (1 RCA video- 2 RCA audio) - 480i or 576i max; Analog audio only to TV
INLINE "Converters" normally DO NOT change (up-convert) resolution; just the method of getting that resolution to the display. (Basically a cable adapter) Up-conversion occurs in the DVD player (like changing a 720p encoded DVD to 1080i output to the HDMI cable) or in the TV itself. This is a digital "slight of hand" that reduces the fidelity of the image (creates video "artifacts" in the displayed image) to give you a "full screen" experience.
Surround Sound requires a digital capable means of transmission like Single COAX ("may be" Orange RCA), OPTICAL cable, or HDMI cable.
HAM CALLSIGN - KC3FFW
Old 09-15-2014, 08:22 AM   #14
Herk7769's Avatar
Here is an AWESOME 3D Blu-Ray capable WiFi (Netflix!) enabled DVD player (HDMI out only) that I use at home. Sears.com
Adding it to the camper is easy and the wattage is so low (14 watts) a 400 watt inverter can handle both the TV and the DVD player.
Output the TV's audio to your surround sound radio system via whatever digital output is available on your TV (similar input also required on your radio).
Old 09-15-2014, 08:38 AM   #15
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by spatterso911 View Post
Genesis GT 3.0 has both bluetooth and HDMI out, 5.1 surround out of the A output , but the price is outrageous.
Well ... my Rockwood arrived from the factory with a Genesis 3.0. So I thought that is what all the Rockwoods would use. I learn sumpin' new every day.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 09-15-2014, 09:44 AM   #16
Herk7769's Avatar
Genesis GT 3.0 has both bluetooth and HDMI out, 5.1 surround out of the A output , but the price is outrageous. Seems that to get decent A/V solutions, 12V is just not the answer.
To be clear; the "A" being discussed is the speaker selection and not an "output." There is no Line level Surround Sound Output other than the HDMI OUT.
There are TWO "Surround Capable" audio only INPUTS: COAXIAL and Optical Digital; both input attachments are accessed from the rear of the Gen 3.0.
Only one can be used at a time and is routed to the speakers via the AU3 selection by pressing the mode button on the front of the unit. (AU1 is the 3mm iPod input socket on the front of the radio).
FYI - AU2 is the SkiFi XM Radio in my camper.
Name:	Gen 3 inputs.jpg
ID:	62838   Click image for larger version
Name:	ZX-800 connections.jpg
dvd
