Old 05-07-2016, 05:16 AM   #1
RV/Marine "UFO" Antenna - not getting reception
Looking for some setup advice as I can't seem to get any signal through the UFO style RV antenna on my 2016 Shasta Oasis 18bh.
Hooked up coax cable to the TV connection (not the satellite connection) inside the trailer. Pushed the button so it's switched to TV/antenna mode vs. cable and the red light is on.
Plugged in a basic 18' Hisense flat screen TV and put it on TV (vs. AV1, AV1, HDMI, etc.).
Thought I hooked everything up correctly, but I don't seem to get anything but a fuzzy screen an any channel I turn it to.
I thought maybe it's the area we're in, but I've tried a few places now, with the same result.
Any advice would be appreciated.
KingstonCamper is offline   Reply With Quote
Old 05-07-2016, 05:28 AM   #2
Ford Idaho's Avatar
From the TV's on screen setup did you do a channel scan?
And is the tv set to antenna?
Old 05-07-2016, 05:30 AM   #3
Yes. I did a scan of the 70 or 80 channels and it didn't pull in any that had reception. I believe the TV had an option to scan via "Air" or "Cable" and I did both.
Perhaps I'm just not in an area that gets reception.
Old 05-07-2016, 05:40 AM   #4
Ford Idaho's Avatar
That is possible.
Have you tried another antenna, rabbit ears or mast type?
Old 05-07-2016, 06:01 AM   #5
fmc
fmc's Avatar
I would check the coax cable. Does the tv work some where else such as in your home?
fmc is offline   Reply With Quote
Old 05-07-2016, 10:26 AM   #6
Cajun Style's Avatar
I have the same problem with mine and I found the Cable from antenna to the booster connector at the booster connector is bad, but there is not enough slack in the cable to repair it I'm going to try to remove he antenna from on top and connect a cable to the existing cable then pull it up through the roof repair it the pull it back through.
Harry-O
Cajun Style is offline   Reply With Quote
Old 05-07-2016, 10:45 AM   #7
Ford Idaho's Avatar
Harry-O
RG59?
If you are going to do that much why not just replace the RG59 with RG6 and two new connectors?
Buy a little extra to work with.
Old 05-07-2016, 11:26 AM   #8
Steelhorzz
Steelhorzz's Avatar
Don't know if this will help, but I had problems will all my TVs to begin with. I started checking the wiring and found that EVERY ONE of the coax connectors were loose!
On the TVs, on the antennas, on the back of the "A/B selector. Once tightened up, everything, (pictures and sound) was much better!
Then a tree limb on my street "removed" my platform antenna.
I purchased and had installed a satellite dish for the roof.
Now everything is soooo much clearer! And many more channels!! I just take my boxes from home on my trips and hook them to my TVs.
2012 Georgetown 360DS Fire Mist
2007 PT Cruiser Auto-stick (4 wheel tow)
Remco Trans Pump /Super Springs Sumo Springs
Blue Ox Tow System / U.S. Gear Unified Tow Brake
Steelhorzz is offline   Reply With Quote
Old 05-07-2016, 12:58 PM   #9
Servicing the antennas on the new trailers we were having a lot of trouble with reception from the multi directional antennas. We had a service rep from the antenna mfr. come to our dealership to help solve our problems. He checked several RVs and said the antennas were working. But we had very little reception. We hooked up a directional antenna and had double the stations and Chrystal clear reception. He said it was because the antenna was focused on those stations, his multi directional antenna was trying to receive from 360 degrees and therefor had weak stations interfering with the stronger stations. When we talked to one of our mfrs. they had us change all the antennas on their fifth wheels we had in stock.
hillsdaletc is offline   Reply With Quote
Old 05-07-2016, 05:13 PM   #10
You must scan for digital channels. No more Analog. Must have a digital TV or converter box.
Harkerr is offline   Reply With Quote
antenna, reception
