Old 01-16-2019, 08:38 AM   #1
RV Refrigerator / freezer not working ?
I have a 2008 34' Cerar Creek 5th. wheel with a Dometic model # RM 3862 frig. Been working fine then 1 day not cooling & ice melting ? Went here to research previous posts and tried it in gas mode ? Took backplate off outside and checked fuse & supply breaker have power ? Felt pipe and it seemed hot which I thought meant it was working but still not getting cold ? Any suggestions from those here all knowing ? Thank you in advance .
LECTRICHUNTRMAN is offline   Reply With Quote
Old 01-16-2019, 09:18 AM   #2
cavie's Avatar
Look at your freezer fins and see if you thermister is in it's proper place on the fins. They get knock off sometime. When you tried gas did you turn off the electroc. The frodge will default to electric if in auto.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-06-2019, 10:39 PM   #3
gmann55's Avatar
I just got mine working! Had to remove it from motorhome and lay on its side! Burped it like a baby and tapped on cooling tubes with a screw driver handle! Reinstalled in motorhome and it works fine now!
gmann55 is offline   Reply With Quote
refrigerator
