Old 07-02-2015, 10:46 AM   #1
Sat/TV
Having a problem I think my 2015 hemisphere has a cable sat/tv wiring issue. I can not get sat to work in living area when hooked to the input on the outside of camper but it will work in the bedroom when I hook it to that port.
ems533 is offline   Reply With Quote
Old 07-02-2015, 11:22 AM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Have you taken the booster wall plate off and look at the connections? Hope these help!
donanddona is offline   Reply With Quote
Old 07-02-2015, 05:32 PM   #3
Took that off its up in the bedroom and all is correct up there, the problem is in the living area. I don't think they have the right wire ran from outside to the living area and I have no idea how to change the cable
Old 07-02-2015, 06:05 PM   #4
Jimmerinwi's Avatar
Sat/TV
It's possible they only ran a direct sat line to the bedroom there was another post I read on here or another forum with the same prob. It sucks because you have a large HD TV the lr and can't hook up an HD receiver. There should be a way to join the sat line in the br to a line running to the lr providing there aren't any splitters on the way to the lr. You would just need to barrel them together in the br.
Somedays I wake up Grumpy, somedays I just let her sleep......(Ray Scott)
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
