Old 01-18-2019, 03:45 PM   #1
Road Warrior
mikedawson's Avatar
Sat TV question
On my previous rig I had a Dish Network Playmaker ant with a Hopper receiver. This setup only worked with 1 TV and since the Ant is powered through the receiver and can't be connected to or ran through the cable TV coax plugin on the RV.
All this being said I do not want to do it this way on my 2018 Georgetown 369 XL. I would like to be able to connect the Ant via a coax directly into the cable TV In connector and then after switching the TV input selector box to Satellite be able to have 2 or 3 receiver boxes connected to 2 of my TV's and this set up function correctly and both TV's being able to watch 2 different channels.
This doesn't seem to be too much to ask but am wondering if and if so which Direct TV set up would accomplish this. I read up on the Pathway X2 Ant and it seems to do this but it says it has 2 coax outputs which makes me believe you have to run 2 cables from the Ant, 1 to each receiver which is not what I want to do. Thoughts or ideas or am I even on the right track? Better yet a system bundle that will do exactly what I want it to do.
Mike
2015 Fleetwood Expedition Pusher
Towing a VW Beetle Convertible
mikedawson is offline   Reply With Quote
