Old 08-08-2013, 03:23 PM   #11
We have the Tailgater and it works well and is easy to setup. If you don't have a clear view then nothing will work except park cable. We got it because it was the cheapest choice that we could find for HD TV. The receiver 211 will only do one TV
so I use the antenna for the bedroom TV. We got the Tailgater, receiver and 50 ft of cable for $199 from a dealer in Florida so no sales tax because we are in Texas.
For that price you must be a new customer and enter into a two year contract. If you don't use it a lot you may be better off with the pay by the month plan which the best Icould find was $349 for the Tailgater, $100 for the receiver and the cable at Camping World. You must do the math for what works best for you. Good Luck
whj77372 is offline   Reply With Quote
Old 08-08-2013, 04:16 PM   #12
Dennis and Julie's Avatar
We also have a Tailgator, yes sometimes we have trouble getting signal but have never been anywhere where we couldn't get something and yes we do camp where there is lots of tree cover. Sometime we put the dish on top of our camper it helps to get signal.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 08-18-2013, 01:53 AM   #13
Yes - As others have posted, if you do not have a clear line of sight to the satellites in the sky, you are not going to get a signal. So no matter what type of SAT dish you have, you must have clear line of sight. Also make sure you are using RG6 cable for your dish hookup. RG5 will work if you are hooking up for a cable tv connection - that is if your campsite provides cable tv - but will NOT work with most satellite systems. I still say the IPhone app "Dish for My RV Satellite Finder" by Michael Berg is the best way to know if you have direct line of sight in the sky. It also works great on the IPad. There are quite a few free satellite finder apps made for android phones too. I just used this IPad app again last weekend with my tailgater. I also helped my neighbor in the next stall who had a regular DISH Network antennae on a tripod who was blocked by a shade tree. Lucky for him that he had a 50 ft. RG6 Cable.
Joedh2 is offline   Reply With Quote
Old 08-18-2013, 08:16 PM   #14
glitelover's Avatar
Reading this thread as we just purchased the Dish Tailgater at Camping World and did a trial setup to make sure everything was in working order before heading out next weekend. We hooked up the receiver with an HDMI cable to the main TV in the living room entertainment center (Rockwood 8311 SS). The Tailgater was hooked up to the outside jack labeled "Satellite." The other end went to a jack marked Aux Sat, which was the only one we could get to work. It acquired satellites and all was well. We have activated everything through Dish Network and will pay as we go since we will probably not use it more than a handful of times a year. Still, we thought it would be nice to have. I think it's great that Dish Network offers this. BTW, good info about the IPad app, which may come in handy later on. For this trial run, we just sat the Tailgater down on the ground and pointed it in the general direction of the southern sky, and it worked great.
Then we noticed all of the other jacks in the entertainment system, so we unhooked the HDMI and tried the other components that are in the entertainment center (and there are plenty of them), but we could never get anything. There is a jack with 3 sets of the old-style red, white, and yellow connections which we hooked up to the back of the VIP 211K receiver, but got no signal. Then we tried with coax to a very prominent "satellite cable in" jack that is just below the TV--nothing with that set-up either. We did check continuity on the outside jack where you would hang the TV from the master to watch outside, and it was hot. There just seem to be lots of jacks with not much happening as far as getting a signal. I wonder if some of those are dedicated strictly to the park cable (?). Just thinking out loud. We definitely aren't doing something right.
HDMI is fine for the main TV, but outside we won't be able to use that, of course, and we are headed to the Bristol NASCAR race and definitely want to view TV outside--that was the main reason we got the Tailgater in the first place--to tailgate
Also, just out of curiosity's sake, where do you set your VIP 211K receiver? The shelf beneath our TV is not deep enough to hold it. I guess we could set it on its end on that shelf. I sure wish there was a pull-out shelf.
Eventually, we'd like to be able to watch satellite TV on the living room TV and the master bedroom TV at the same time--I know the VIP 211K is not a dual receiver, so I realize if it's doable that both TVs would have the same channel, but we're fine with that. I know there are HDMI separators or splitters or whatever they're called. I've seen them with HDMI jacks that say "out" and then "in 1" and "in 2." Could something like this conceivably be used to accomplish this? I was thinking of trying to hook an HDMI to the back of the receiver, run the other end to this "splitter," then run 2 separate HDMI cables, one out to each TV. I have no idea if this would work. I think these are actually made for the application of attaching Blu-Ray and XBox, etc. to a single TV, but just wondering if it might work to hook 2 TVs to the sat receiver.
Otherwise, I guess the bedroom TV could be on antenna while the living room is on satellite, though that would not be our preference because of the limited channel availability over the air.
Thanks for any help.
________________
2013 Rockwood Signature Ultra-Lite 8312SS
2012 Ford F-250 XLT SuperDuty with towing package
glitelover is offline   Reply With Quote
Old 08-18-2013, 08:33 PM   #15
I'm not familiar with your RV so can't answer many of your questions.
HDMI is the way to go for the living room TV. The HDMI splitter is a great way to go if you have a way to run the HDMI car to the other TVs. Someone on these forums used a wireless system to transmit the HDMI to a remote TV.
There is also a modulator output (coax) on the back of the 211. If you can wire that to the "Set 2" output of your antenna amplifier booster control then that will distribute the same-channel signal (in SD) to all the other TVs.
Old 08-19-2013, 08:10 AM   #16
glitelover's Avatar
Thank you for your reply. We will be looking at this again tonight when hubby gets home.
I don't know if a photo of our entertainment configuration might help you help me, LOL, but just in case, it looks a lot like the photo below (this is a Rockwood stock photo).
________________
Old 08-19-2013, 01:53 PM   #17
Entertainment Center in RV
The picture you attached for your entertainment center is very similar to mine. I have the Surveyor SP-240 with a TV turntable that rotates between the bedroom and the living space. I did mount my satellite receiver unit in the cabinet but I had to put it on it's side. I used appliance mounts that I purchased at Camping World. These hold the unit in place so it is not bouncing all over the inside of the cabinet. I also purchased a IR repeater from EBay. Got one for about $30. The IR repeater lets me use the remote for the sat receiver while it is in the cabinet. I had to add a power strip inside the cabinet too since I only had two outlets in the media cabinet. I added one with a surge protector on it so it could power the TV, Sat receiver, IR repeater and a power adapter for my IPAD. I got the IPAD HDMI/charging cable from the apple store. This has come in handy at times where the RV parks have free wireles internet and I can stream Netflix movies from my ipad to the TV in the second HDMI port. My SP-240 has a few coax hookups. One for the input and another inside the entertaiment center to the TV and another next to the outdoor kitchen for a second TV connection. What I found out is that this only works for cable. I tried to connect my Sat Receiver coax output to the coax connector in the media center cabinet - hoping that it would send the signal to the outdoor coax connector next to my outdoor kitchen - but that did not work. Someone else did mention a wireless HDMI transmitter/receiver. My friend bought one of these off of EBay and suprisingly it worked pretty well but it was pricey at $250. I am sure you can find them cheaper online. Considering all the effort that you would have to either pay for or do it yourself to run another HDMI from where your Sat receivier is and buy an HDMI splitter, the $250 for a wireless HDMI transmitter and receiver unit isn't that bad. Just be careful about the range of these wireless units. If you are using around your travel trailer you shouldn't have a problem. However, depending on the amount of metal used in the construction of your RV can impact the signal from the transmitter to the receiver. If you are withing 30 feet of the transmitter is should not be a problem. Also - if you are going to buy one of these HDMI transmitter/receiver units, make sure that it transmitts Video and Audio. Some of the cheaper models do not transmit Audio. In this day and age of tecnology, you would think that the modern RV's would have HDMI inputs from a the media center to all outputs where they have place coax connectors. I don't know of any modern flat screens that do not have HDMI. Anyways, I hope this helps a bit. There have been a lot of good replies to these posts and I thank everyone for their input on this subject.
Old 08-20-2013, 08:45 AM   #18
I was thinking about that "satellite cable in" jack. It sure does sound like its made for that modulator output from the receiver to the other TVs. Do you have a "Cable" input on the outside your RV as well as the Sat input you connected the Tailgater to? If you do not, then my guess is that the "satellite cable in" is wired to the Cable Input port on your antenna booster control.
That would mean that it will distribute the modulator output to your other TV jacks only when the antenna booster control is OFF. You do know that you would have to re-scan for channels on the TV when you are trying to use the modulator output, right?
Old 08-20-2013, 09:10 AM   #19
BombDoc's Avatar
Tailgater
Just purchased the Tailgater from CW last weekend. I am a Dish customer so I called them and swapped out a receiver I had in the house for the Vip211k. I also purchased the "Dish for my RV" app for my iphone and it all seems to be working as described. I set up a small TV on my back deck, ran some extension cords to power the TV and Receiver and within 10 minutes I was watching ESPN in HD. Now to get it to work inside the RV. DW and I are big tailgaters and looking forward to college football (9 Days for us) and can't wait. My plan is to set a 46" TV on a table outside the RV to watch the game, eat, have some brews. I'm not too concerned about that set up because it will be no different setting it up at a game than it was setting it up on my deck. Does anyone have any suggestions on how to get it to the main TV in the RV? I'll worry about trying to get it to the bedroom once I get the Main TV up and running. Thanks
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 08-20-2013, 09:21 AM   #20
Does your RV have two coax "inputs" on the outside (Cable and Sat) or one input (shared)?
Does your RV have any coax outlets marked as "Sat" at secondary TV locations (bedroom)?
