Old 01-11-2020, 10:19 AM   #1
Satellite and cable hookup
We just bought a new2019 flagstaff 29rkws . Behind the tv is a coaxis jack labeled from satellite receiver, my satellite receiver (dish Wally) only has hdmi output jacks . Can anyone help explaining how this works and how to hookup.Thanks
ID:	221691   Click image for larger version
Santafe2343 is offline   Reply With Quote
Old 01-11-2020, 02:16 PM   #2
bubbles's Avatar
The Wally also has RF (red/white/yellow) composite video/audio outputs and if it is impractical for you to run HDMI these outputs can be used to convert to coax and make the connection from the SAT receiver (Wally). An RF modulator is cheap (less than $15.00)) and works quite well. The TV viewing may not be HD but SD is pretty good.
Old 01-11-2020, 04:36 PM   #3
Thanks Bubbles I was was planning to run hdmi cable from satellite receiver to tv. Couldn’t figure out how coaxial would work, the tv has a hdmi pluged into It already just wondering what it’s for or from, will have to wait till it’s plugged into shore power to play with and see what is what with satellite and cable.
Old 01-14-2020, 07:52 PM   #4
Hi, I just had a similar issue with and HDMI cable already plugged into the TV on our new Sabre. It ran from the TV to the radio, maybe yours is the same?
Barry
ex-egll is offline   Reply With Quote
Old 01-14-2020, 08:32 PM   #5
Thanks Berry
Old 01-15-2020, 02:46 PM   #6
I just looked at this issue yesterday. Amazon has coax to HDMI converter boxes relatively inexpensive.
2019 FR Wildwood X-Lite 271BHXL
2006 Ford F350 SuperDuty Bulletproofed 6.0 with Husky Centerline TS WDH
22" Weber Smokey Mountain and a Green Mountain Grills Davey Crockett
Countryhb is offline   Reply With Quote
Old 01-15-2020, 03:07 PM   #7
What type of satellite antenna are you using? Was it factory ordered or dealer installed? I
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 01-15-2020, 05:44 PM   #8
code.org
moff34's Avatar
My Wally has a coax connector. I put a coax jumper from the outlet on the wall to the Wally, then an HDMI cable from Wally to the IRV66. Made for a clean install.
moff34 is offline   Reply With Quote
Old 01-17-2020, 04:50 PM   #9
What is a WALLY????
Jim in Halifax is offline   Reply With Quote
Old 01-17-2020, 05:10 PM   #10
code.org
moff34's Avatar
Wally Receiver
Originally Posted by Jim in Halifax View Post
What is a WALLY????
As the OP stated he has DISH satellite service and a Wally receiver. The Wally is a small receiver sold by DISH, with no DVR capabilities unless you add an external SSD, which connects to your satellite dish and your television. If you have a satellite dish that is capable, the Wally will work with the dish to automatically align it to find the satellites. I use a Winegard Pathway X2 with my Wally receiver and it has worked great all across the country.
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights '21-42 Nights '22-86 Nights '23-65 Nights
cable, lite, satellite
