Old 03-24-2015, 10:02 AM   #11
Mr. Dan's Avatar
Crickets....................................
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 20
Old 03-24-2015, 09:09 PM   #12
Left Coast
Good one! If a person doesn't have a way to 'tone' a wire, I've taken a 50' cable,screwed it on to the outside connection, brought the loose end in, got out meter and ohm'd the center signal wire with one probe and into wall connector to verify plugs labeled right. it's only a starting point.
Old 03-24-2015, 09:47 PM   #13
Start dirty and cheap, check the cable ends and the connectors. You could turn off the booster, short out the plugs to the ground one at a time and check for continuity. If your home runs are good , bypass the amplifier and put a barrel end to the plug going to the tv and check the signal. Usually the cable run and satellite run are different color wires, make sure they are connected correctly.
2012 Dodge Ram 2500 Limited 4x4 ramboxes
2012 Chevy Tahoe
2011 Yamaha Venture
Wildwood 241QBXL
dacheedah is offline   Reply With Quote
satellite
