Old 01-04-2016, 10:55 PM   #1
Satellite connection location on 31DBTS (2016)
Getting sattelite hooked up tomorrow by direcTV but can't find our outdoor sattelite hookups and I'm afraid the tech won't know what he's doing and want to drill holes. It's a 2016 Puma DBTS. It's prewired for sattelite so you'd think it'd be easy, maybe I'm just blind? Thanks!
AdamsPuma31dbts is offline   Reply With Quote
Old 01-04-2016, 11:22 PM   #2
the prewire from what ive seen on other units means just that. the wire is run though the trailer and up into the roof, but they do not run it through the roof. They leave the wire laying inside the roof and have the roof marked with the location to drill to find the wire.
If you cant find the location to pop a hole in the roof before the satellite tech gets there. Just have him run a temporary line through the door or a window (if your unit doesnt have any other satellite/cable jacks in one of the compartments), that way he can at least get it functional and know everything is working. Then when the location is found, the satellite can be wired properly without having to hack up your roof.
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
cat, location, satellite
