Old 07-19-2012, 08:55 AM   #11
lindy's Avatar
mike54 could be a simple fix, they may have just accidently swapped the cable coax and the sat/aux coax. Open up the outside connection and not the coax colors, then remove the TV amp and not the coax colors there. Might be a simple swap op coax's.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-23-2012, 11:17 AM   #12
Originally Posted by hp178 View Post
I think the problem lies with the wiring in the trailer. It is probably using a basic cable splitter and not a satellite splitter. Same thing happened to me years ago at my house when I tried to use a cable splitter on a directv feed to power 2 receivers. Each receiver only showed half the channels.
What is the solution? Do I have to run the cable from the dish directly to the reciever through a window. Is there anyway to find where the basic splitter is and change it to a satellite splitter. I would appreciate any information you can give me.
BlueRidge2013 is offline   Reply With Quote
Old 07-23-2012, 11:29 AM   #13
TURBS's Avatar
All my splitters were behind the entertainment center.
