Old 01-04-2016, 09:39 AM   #11
Left Coast
The wall plate with the green light is the booster, on back side of plate.
Old 01-04-2016, 10:36 AM   #12
rracer5's Avatar
Pull your wall plates labeled for Sat. and Sat/Aux. Almost all the newer units I've seen and/or helped other people diagnose use ORANGE cable for Satellite service. As previous post have already said, satellite is usually straight runs from point "A" to point "B" (no splitters). IF there are splitters involved (I doubt it) they have to be special satellite signal type. But, that shouldn't change the fact that the satellite coax is ORANGE.
Does your unit have a central area for ALL your hookups (docking station)? Mine has 3 coax connections outside. 1 for "Park Cable" which feeds all Tv's in the trailer, & 2 Satellite connections (1 for the livingroom & 1 for the bedroom Tv's).
So, if you find ORANGE coax behind your wallplates at the Tv's but no ORANGE coax in your outside connection area then, it sounds like they forgot to install the connection plates. You may have to remove some panels (if possible) and see if they left the coax(s) laying behind. If they're there then just install new connection plates if you have the room.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-04-2016, 11:41 AM   #13
Canadian Member
itat's Avatar
Hopefully you'll have something like this on the exterior of your Silverback. It would have either two cover flaps like in the picture or one that covers both sides. It would be unusual for the factory to not install this if you have Sat hook ups inside, but it's not unheard of that they'd forgot to connect the RG6 cable to the back of the connectors at either end.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 01-04-2016, 12:23 PM   #14
SnP
As rracer5 stated, they are in your docking station. This is where your water connection, outside shower etc... is located. The black outlet on the door side is actually for connecting an outside tv.
Steve and Paula, Tiki and Keyla, RIP Chance
2017 Ford F-350 Platinum DRW, 6.7L
2018 Cedar Creek Champagne 38EL
Camped - 2014-47, 2015-104, 2016-100, 2017-161, 2018-10
SnP is online now   Reply With Quote
Old 01-04-2016, 12:59 PM   #15
arpipeliner's Avatar
This is my 2010 29RE.
Inside
Name:	ImageUploadedByForest River Forums1451933635.236344.jpg
Top coax says aux/sat. Bottom is cable or over the air. On my the satellite is the top one.
Outside
Name:	ImageUploadedByForest River Forums1451933778.762366.jpg
The black coax is my satellite. The white one is cable(first time I have used it). Free in the park.
Hope this helps. Never have put a receiver in bedroom yet. No help there.
arpipeliner is offline   Reply With Quote
Old 01-04-2016, 06:04 PM   #16
TimfmCt's Avatar
Inside
Attachment 97249
Outside
Attachment 97250
Thanks you all for your help. I found the two covered coax connectors in the bay where the dump handles etc. I've put the tv on hold. I'm still trying to make the creek more sturdy, So far I've installed a device inbetween the wheels. Next is to deal with the unbelievably steep stairs.
I'm still surprised how the owners manual provided does not match major items. There are "a" "b" and "c" speaker choices. So far I've found "a" and "c". I can't hear anythibg on selection "b". any ideas?
Is there a owners manual for the 2012 29RE?
Tim fm Ct
2012 Silverback 29RE
TimfmCt is offline   Reply With Quote
Old 01-04-2016, 06:06 PM   #17
TimfmCt's Avatar
Inside
Attachment 97249
Outside
Attachment 97250
Yes, I have those cover plates too. Mine are side by side.
Tim fm Ct
Old 01-04-2016, 06:48 PM   #18
Think "b" would be the bedroom speakers if equipped. Mine is not. Just remember "c" is outside speakers. It plays on the DVD player. Luckily my neighbor was laughing about hearing Talladega Nights while he was grilling.
Things can be pretty lacking on explaining. Just ask. I learn stuff on the forum all the time.
Old 01-05-2016, 07:58 AM   #19
TimfmCt's Avatar
Thanks.
If no speakers are visible in bedroom might the bedroom still be wired for them?
Tim fm Ct
Old 01-05-2016, 08:16 AM   #20
Left Coast
Might need to remove radio to see what's plugged in on back
satellite
