Old 06-25-2015, 02:17 PM   #21
I have Direct TV and frequently get the no signal at startup. only my screen is blue, not black. Wish I could tell you the exact procedure but my DirectTV remote has 2 buttons labeled TV input; the other Format. I fiddle with those. If that doesn't do it my TV remote has a button labeled Source and that usually gets me a picture. I know this is much help, but i think that the Dish folks could tell remotely if the receiver was bad. Direct TV support couldn't figure mine out either.
rainsmik is offline   Reply With Quote
Old 06-25-2015, 02:45 PM   #22
Originally Posted by lbrjet View Post
When you power up the receiver the Tailgater should be making noise if it getting power and working. Something to check.
I do remember once having a problem and Dish instructed me to pull the card out of the receiver and push it back in. Did some kind of reset I guess and I have never had a problem since.
You can check the power at the receiver and at the end of the cable that plugs into the tailgater with a volt meter. Should be around 19 volts. King Controls had me do this and determined the cable delivered with my unit was bad. They sent me a replacement.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
We tried the pull the card out and put it back several times it did nothing sigh!
2017 Grand Design Reflection 367BHS 5th wheel.
2017 F350 crew cab 6.7 4X4 srw.
clicker1944 is offline   Reply With Quote
Old 06-25-2015, 02:46 PM   #23
Thumbs up dish sat. promblem
I have a Direct tv all i do is push a button and pop picture. But if i don't have the right input on my tv voila no picture and nothing on screen . So check input on tv.
outloud is offline   Reply With Quote
Old 06-25-2015, 03:16 PM   #24
DKRITTER's Avatar
We had a similar issue and tried a little bit of everything and finally took the tailgater back (the new grey one) and picked up a Winegard Pathway X2 and haven't had any issues since.
DKRITTER is offline   Reply With Quote
Old 06-25-2015, 04:10 PM   #25
Check to see if card behind little door on receiver is in slot correctly. Mine came out once.
RetCityMan
CityMan is offline   Reply With Quote
Old 06-25-2015, 04:42 PM   #26
RetCityMan
As many times as we pulled it out and replaced it that would not be an issue.
Old 06-25-2015, 04:43 PM   #27
That's the one I have the new grey one!
Old 06-25-2015, 06:03 PM   #28
Might try direct connection from dish to receiver.
Harkerr is offline   Reply With Quote
Old 06-25-2015, 06:07 PM   #29
That's exactly how it's connected, through the window.
Old 06-25-2015, 06:48 PM   #30
When we bought our tailgater the dish rep said I would need to have my receiver plugged into my home dish to keep the receiver current. If the receiver has been sitting unused for weeks it won't find a signal. Did Dish customer service tell you anything like that? If you have dish at home you may want to test the receiver at home.
Fred & Christine
2013 Columbus 320RS
2016 F250 Lariat 4X4 Short Bed
2015 Nights Camped 72
2016 42
2017 15 so far
Fred and Christine is offline   Reply With Quote
satellite
