Old 06-24-2015, 09:49 AM   #1
Satellite has no signal
Our 2nd trip with the Dish setup. VP211z and King Tailgater. Intial set up all was good after Dish activated it and it did its thing. That was 4 weeks ago now I put the Tailgaiter out, coax into the receiver, set all the correct inputs, hdmi into the tv and all I get is a black screen with the box that says "weak or no signal". It never even tries to go into setup mode at all. From the previous trip it should do all the setup and then advise if there is a problem with the signal. Dish customer support tried all the resets then advised me to call a local Dish retailer. They want 150 bucks just to come out...not gonna happen. I think the recei er is bad. If I try to shut it off with the remote or the power button it will not go off! I have to unplug it to shut it off. The remote works the tv fine so its not the batteries. Should also mention when it did work on the first trip it would shut off the sound several times when changing channels. I had to power down and up to get the sound back. Doesn't sound right to me. In my opinion I got a bad receiver but just wanted some input before getting back on the phone with Dish and venting. At least this park has cable so we do have tv in the meantime.
2017 Grand Design Reflection 367BHS 5th wheel.
2017 F350 crew cab 6.7 4X4 srw.
clicker1944 is offline   Reply With Quote
Old 06-24-2015, 09:57 AM   #2
clr
Sure sounds to me like the receiver may be bad. The TV should still display the setup screen and complain about low or no signal from the dish even if the antenna is disconnected.
clr is offline   Reply With Quote
Old 06-24-2015, 10:23 AM   #3
TURBS's Avatar
I think the tv is on the wrong input.
With the receiver turned off there should be a dish logo / screen saver.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-24-2015, 12:41 PM   #4
I agree with Turbs, check your HDMI input menu on your TV. Sounds like it is on antenna.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-24-2015, 12:43 PM   #5
TURBS's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Ooooor the hdmi cable is bad?
If you have another it can't hurt to try.
TURBS
2011 32bhok Sabre
Old 06-25-2015, 08:38 AM   #6
All inputs are set correctly, hdmi 1, and bought a new hdmi cable since that was the easiest one to fix. Still no set up screen. Don't forget I also said I can't turn the receiver off unless I unplug it. Cable works fine as does the antenna. Believe me I have been rv'ing for years I know about inputs and the little antenna button, etc. It's got me stumped.
Old 06-25-2015, 08:41 AM   #7
TURBS's Avatar
Did you try a reset "hold power button"
I might agree receiver may be bad then.
in 25 years with dish I've not had a bad one.
TURBS
2011 32bhok Sabre
Old 06-25-2015, 08:55 AM   #8
Tried that with Dish customer service. Hold for 5 sec then release...nothing!
Old 06-25-2015, 08:55 AM   #9
accumack's Avatar
Have you gone into setup and put the zipcode for where you are staying. It's the way the dish knows where to aim for the satellite.
accumack is offline   Reply With Quote
Old 06-25-2015, 08:59 AM   #10
As I said I can't get the set up screen to even come on. Just black screen with th box saying little or no signal. Believe me the setup screen would be very welcome to see.
satellite
